extremecarver Posted February 10, 2024 Author Posted February 10, 2024 Actualy the same channel has videos showing assembly too - maybe it was so hard because I didn't remove the SSDs. As for the display, I guess you really need panel and a new bezel. Then you should be fine. Never buy a new panel without also getting a new bezel. Old bezel won't do after being unglued.
extremecarver Posted June 1, 2024 Author Posted June 1, 2024 So the next default appeared. The fan started rattling. Guess I have to buy a new fan too. BTW - I noticed that if PCIe Link Power State Management is not set to lowest state, the Gram needs 3-4watts more - which means the fan kinda has to work all the time at least if connected to a 4k display. That's the default for plugged in state in Windows - so that's really a setting to change. It's much less a problem if using internal display however. In General it's quite noticeable that the Iris XE gets pushed much harder if using 4K display. I was thinking about buying a 6K display used - but may think twice about it as maybe the Gram in that case really won't be silent anymore. And I'm pretty sure those paint chips happen due to sweat. Now that I haven't used the gram in the heat it's all perfect after 3 months. When I got it new and worked often in the heat - at the front there had been the first chippings appearing. I'm pretty sure it wasn't defective. I really should have warrantied that paint chipping off when buying and when it first appeared in hindsight (would have given me a new keyboard too). 3 years in - I will upgrade once LG Gram with Lunar Lake gets some discounts. Lunar Lake finally looks like Intel pushing a really good processor aimed at sipping battery only and will be produced at TSMC N3P node. So I guess it will mean OLED at 12-14 hours runtime or 24 hours runtime for LCD display versions. I really don't see the huge advantages of the current LG Grams except the brighter displays. If I upgrade in 1.5 years time my Gram will have served me very well.
extremecarver Posted January 10, 2025 Author Posted January 10, 2025 So, by now also replaced the fan. A new one was 33€ from Aliexpress including shipping. My new front cover has a crack besides the keyboard - it doesn't matter much I think however. happened while trekking and stuffing the laptop into the carry bags for the support animals. Yeah - my gram has to take a lot of abuse... I'm not happy about the new battery - it somehow just doesn't achieve that great runtimes anymore. 8-9 hours realistically it is. Maybe windows is just using more and more resources and I haven't done a fresh install ever (but cleaning up programs, autostarts, whatever). And lunar lake gram still isn't released. I guess I have to wait at least another year for decent price for lunar lake gram. Then besides the battery life I don't see a reason to upgrade yet anyhow - nearly 4 years in now - so overall it held up really well. Never had a laptop over 4.5 years before. Next default is - the lower left corner screw system - meaning the thread you screw in the screw was into pieces when I opened it. So one screw less....
RS4 Posted January 10, 2025 Posted January 10, 2025 My Battery wear level is now at 21.8%, I use it mostly plugged in so don't care. The outer body, screen, keyboard etc is holding up well, specially the white finish and colour.
John Ratsey Posted January 11, 2025 Posted January 11, 2025 On 1/10/2025 at 11:28 AM, extremecarver said: I'm not happy about the new battery - it somehow just doesn't achieve that great runtimes anymore. 8-9 hours realistically it is. Maybe windows is just using more and more resources and I haven't done a fresh install ever (but cleaning up programs, autostarts, whatever). What does BatteryInfoView report as the battery statistics and power drain when idle or light usage?
extremecarver Posted January 27, 2025 Author Posted January 27, 2025 When idle I get down to 0.7w. Battery capacity after 1 year dropped from 76 to 72mAH (yeah I guess the original LG batteries through the official LG reseller in Austria - are a bit older nowadays). The problem is that even with a lot of cleaning up of processes and so on - Windows just constantly loads 2-3w of power on the CPU even when idle. This has gotten much worse year for year with Windows 10. In the first 2-3 years 10 was pretty sleek - now basically just with standard updates it got very bloated and just moving the mouse the SOC power goes up to 2-3w. Also both Chrome and Edge bloated up in consumption. 3-4 years ago the edge nightlies with the battery saving modes worked great, once it got into the trunk edge a lot of those savings had been removed, until 1-2 years ago I noticed now Chrome runs more efficient vs edge and switched back. I guess the only way is to go for Intel Lunar Lake or up to date AMD. With the bloating of browsers and windows - it needs a much more efficient cpu/mainboard. Yeah - not sure about Windows 11, 2 years ago I downgraded back to 10 after 5 days because it was draining more battery plus horrible UI. I still need 2-3 programs that don't work on Linux regularly, Otherwise I would go for Ubuntu. By now Ubuntu runs with much better battery efficiency on the Gram vs Windows 10. Oh yeah - and no antivirus at all. That would drain even more. Oh yeah - old battery I think if I remember correctly worked pretty well up to 500 full cycles. But I think summer use each year for 2-3 months at 30-35° and winter use every year once for 10 days or so at -10° did strain the battery a bit. I think I replaced it with 56maH and 600 cycles or so. Up to 500 cycles it had barely degraded, from then it went downhill fast. But that also shows to me - restricting at 80% is not my cup of tea. After 3 years I pop in a new battery (that likely was produced some years ago as it cannot hold as much charge as original when new) and that could do another 2-3 years. But then I think in 1 year of time it will be a Lunar Lake LG gram. Actually I have never before used a laptop longer than the LG Gram before. However I also never replaced so many parts. This may be less to the quality of the LG, but more that upgrading to new technology is less and less regular needed as improvements each generation get smaller and smaller. Actually for intel CPU to me 11-14th generation is all the same. Only with Lunar Lake have they finally produced a package that is actually better than 11. gen. Yeah there is no AMD Ryzen to all our dismay. But for me Intel Lunar Lake is a tiny notch above the current Ryzen platform. My Lenovo T440s made it nearly 4 years (until I replaced it with a T480s that I used less than 2 years as it just wasn't a really good laptop). But durability on the Thinkpads was a little above LG. The LG is superb for it's lightweigt package however, and for me overally better than Thinkpads. The keyboard on the LG is not up to older Thinkpads (especially in durability). And yeah other stuff like enclosure or the fan is also a bit flimsy over time. I didn't treat my Thinkpads better - though I didn't use them as much on battery and never as much in really hot countries without aircon...
Samir Posted March 9, 2025 Posted March 9, 2025 On 2/7/2024 at 5:38 AM, extremecarver said: And no I already cleaned the ad card reader thoroughly, no help. It's soldered onto the sub board so no connector to check either. Sub board is clearly well connected as otherwise no charging possible or switch on. A little late to the party but something I've found that works very well on reviving circuits is CRC brand Contact Cleaner. Be sure to follow the instructions and make sure there's no power of any sort (have to disconnec the battery probably), but I've seen it revive circuits that were deemed shot by the manufacturer. Something to try.
Samir Posted March 9, 2025 Posted March 9, 2025 Weird, the forum didn't tell me my post was posted, hence the double post.
extremecarver Posted March 26, 2025 Author Posted March 26, 2025 The thing is that this is very likely no contact problem. Not gonna invest much I to it. By now the new keyboard and front assembly got a big crack, likely from strapping the laptop with high force inside a duffel bag onto a mule. Kinda snapped. 3-4cm long on the front and through the hole side and some mm on the back. Also one of the 4 main screws Holding the laptop together in the lower right corner the fixation where the screw screws into broke into pieces.. but yeah that's all cosmetic and laptop still going strong... I do think I won't replace it before March 2026 when I will buy a lunar lake gram or similar to replace it. 5 years will be a new record for me to keep a laptop. Yeah the ThinkPad Ts series was more sturdy but the gram is overall better for me.
John Ratsey Posted April 6, 2025 Posted April 6, 2025 On 3/26/2025 at 1:25 AM, extremecarver said: By now the new keyboard and front assembly got a big crack, likely from strapping the laptop with high force inside a duffel bag onto a mule. Kinda snapped. 3-4cm long on the front and through the hole side and some mm on the back. Also one of the 4 main screws Holding the laptop together in the lower right corner the fixation where the screw screws into broke into pieces.. but yeah that's all cosmetic and laptop still going strong... I do think I won't replace it before March 2026 when I will buy a lunar lake gram or similar to replace it. 5 years will be a new record for me to keep a laptop. Yeah the ThinkPad Ts series was more sturdy but the gram is overall better for me. I have had some very sturdy notebooks in times past which were more likely to cause damage than be damaged. Bend the display slightly and it would crack. Bend the chassis slightly and the mainboard might crack or, as a minimum, a connection would be upset. The first notebook I owned which was less sturdy was a Sony G11 (2007) which had a 12.1" display, weighed 1.13kg and had a decent battery life. I discovered that the chassis or the display could be bent a little without any adverse effects. The drawbacks were a single core CPU and a 1024 x 768 display at a time when dual core and higher resolution were becoming the norm so I didn't keep the notebook very long. LG has combined lightweight materials with thinness which makes the overall product more flexible. The electronics can tolerate this fairly well as the mainboard has shrunk from being the full width of the notebook to something the size of a postcard which is joined to other parts by ribbon cables. Your Gram 17 has revealed what happens under severe conditions, but chassis problems can usually be fixed with some tape or glue. However, when I take my SuperSlim on holiday I will be surrounding it with clothes to minimise the risk of bending and possible damage.
extremecarver Posted August 23, 2025 Author Posted August 23, 2025 The new battery is dropping fast - now at 147 cycles it's already down to 66.000mWh, the original one I exchanged at 60.000 or so. Seems the main problem is simply aging and even if getting a new original battery as they were produced long time ago - it's a disaster. I found out that Windows 11 completely reset any battery related settings in the registry, so after redoing them battery life got better again, but yeah it's still inferior to Windows 10. Well I guess one more year on the Gram then I will upgrade to a new one. LG from time to time really dumps the old ones at cheap prices.
Ngoc Nguyen Vietnam Posted September 19, 2025 Posted September 19, 2025 I recently purchased this laptop Gram 2025 17", and used it normally, taking good care of it. However, after just about two months, the screen became damaged, LG technician said there is a small crack in the middle of the bottom screen. The warranty staff visited, then later called to inform me that, despite the laptop still being under warranty, I would have to pay for a new screen replacement. When I bought the laptop, the sales staff advised against choosing the 17-inch model. LG must take full responsibility for this screen defect. Even as advertised this laptop as having "military-grade durability and features MIL-STD." There are no scratches on the screen or the laptop itself. Initially, there was only a small line on the screen, which later spread. The "internal crack" that the warranty staff mentioned is located near the sturdy hinge area, with no evidence of strong external impact. LG should take 100% responsibility for this issue but they push me to purchase the screen at cost around 300 USD. This time I am deeply disappointed with the warranty service for the LG Gram laptop. I have used about 10 laptops from various other brands and never had to deal with warranty issues before. This is an expensive laptop costing about 1400 USD, yet its quality is poor, and the warranty service is substandard. LG is a bad player in Notebook.
extremecarver Posted November 4, 2025 Author Posted November 4, 2025 It's slowly getting time for replacement - the next default: my top USB-C port isn't charging anymore. The case is slowly warping more as well (the lower part as the upper part is still quite new)... But I'm pretty confident it will survive 5-6 more months until replacement with the current Gen at affordable price. Battery on the other hand has recovered a bit again at 172 full cylcles back to 68.000mWh.. Looking like it will make it to 5 years (well with exchanged keyboard and exchanged battery and exchanged fan). I also feel like the overall brightness isn't where it was when it was new. I usually need to run it now at 90-100% instead of 80% when it was new during the day.
RS4 Posted November 6, 2025 Posted November 6, 2025 I have a keyboard problem, some keys I have to press twice now to get them to register. What may be the problem, may be dust? What is the procedure to get to keys?
extremecarver Posted November 9, 2025 Author Posted November 9, 2025 Take the cap off and put it back on for those keys. But basically after trying that a couple of times and getting it back to work for a few weeks it means exchanging the keyboard which is isn't easy as you can read on the previous page. I think it's just the life over of the switches. E will be the most likely to break due to heaviest use in most western languages 1
RS4 Posted March 9 Posted March 9 I think keyboard failure is the most common issue with the Grams now, LG has fixed most of the stuff year after year but keyboard failures continue over different generations. On searching keyboard on such a small subreddit: https://www.reddit.com/r/LGgram/search?q=keyboard&restrict_sr=on&include_over_18=on&sort=relevance&t=all
extremecarver Posted March 12 Author Posted March 12 But not sure about the pro. It has a different keyboard. But likely too new to already have many with problems. Just 2 years now.
