https://www.nvidia.com/en-us/design-visualization/rtx-4000-sff/
The new desktop card is very interesting! 20GB across a 160-bit bus (a first I believe), half-height, dual slot, and no external power required - only 70W. I wonder where it will land compared to the Ampere A4000.
Here is a pdf with the new mobile parts: https://nvdam.widen.net/s/dmdqnnwcmk/proviz-mobile-linecard-update-2653183
Pretty much what was expected. I bet the "3500 Ada" is what the 4070 Ti mobile will end up being. I wish the 4070 mobile had those specs to begin with.
Edited by Nigh on Noon
I mistakenly called it the "A4000 SFF Ada," but its actually just "4000 SFF Ada""
Dell Precision 7710: i7-6820HQ  | 64GB DDR4-2666 | Quadro M5000M | UHD 60Hz
Desktop: Xeon E5-1660 v2 | 24GB DDR3-1600 | GTX 1080 | Dell S2721DGF, Dell U3014
I need that ada 4000 in mxm format 😄
You know, I was thinking, given that its only 160-bit and 70W, it should easily translate to a laptop form factor. Can you imagine 20GB in a laptop? That would be sexy.
  • Nigh on Noon changed the title to Nvidia announces RTX 4000 SFF Ada, and Ada mobile workstation lineup
So, the A2000 Ada actually has the same amount of CUDA cores and bus width as an RTX 4060 Mobile whereas the the Ampere A2000 is just a 3050.
This would be epic in MXM type A format
Dell Precision 7520: Intel Core i7-7920HQ, 32GB RAM, NVIDIA Quadro T1000 4GB, LG LP156QHG (240Hz QHD, 100% sRGB & P3, 400 nits), Intel AX210 WiFi 6E
Dell Precision 3591Intel Core Ultra 7 165H, 64GB RAM, NVIDIA RTX 2000 Ada 8GB
Dell Precision M4800: Intel Core i7-4810MQ, 32GB RAM, NVIDIA Quadro M1200 4GB, Intel AX200 WiFi 6
ThinkPad T440p: Intel Core i7-4980HQ i5-4300M, 16GB RAM, Intel Iris Pro 5200 HD 4600, N140HCE-EN1 Rev.c2 (1080p)
ThinkPad X1 Carbon Gen 2Intel Core i5-4300U, 8GB RAM, Intel HD 4400, QHD
ThinkPad X230: Intel Core i5-3320M, 16GB RAM, Intel HD 4000, 16:10 2K display
ASRock X570M Pro4: Ryzen 9 3900X, 32GB DDR4 3200MHz, NVIDIA GTX 1070 8GB, Corsair Crystal 280X, Xiaomi Mi Curved 34 + Acer Predator Z35
