jcordero Posted May 28, 2023 Posted May 28, 2023 Is it possible to upgrade the P870 to the beastly Quadro P5200 from the GTX 1080? I could only find guides to upgrade to the Quadro P5000.
Tenoroon Posted May 28, 2023 Posted May 28, 2023 44 minutes ago, jcordero said: Is it possible to upgrade the P870 to the beastly Quadro P5200 from the GTX 1080? I could only find guides to upgrade to the Quadro P5000. Should be. I've seen listings for heatsinks designed around the MSI P5200 for the TM, so I would believe any P5200 would work. Clevo P870TM-G: Core i7 8700k @ 4.8ghz | Clevo RTX 2070 Super | 32gb HyperX DDR4 @ 3200mhz | 17" 1440p 120hz B173QTN01.0 Screen | 256gb Samsung 850 EVO | 500gb WD Blue SSD | Prema BIOS Alienware 17 R1: Core i7 4710mq @ 3.619ghz 741 CBR15 (834 CBR15 @ 4.213ghz) | Dell GTX 860m | 16gb HyperX DDR3L @ 2133mhz | 17" 3D 120hz LTN173HT02-T01 Screen | 256gb mSATA SSD Asus Zephyrus G14: Ryzen 7 4800hs @ 4.2ghz | GTX 1650 | 16gb DDR4 @ 3200mhz | 14" 120hz LM140LF1F01 Screen | 512gb NVME SSD
jcordero Posted May 28, 2023 Author Posted May 28, 2023 12 hours ago, Tenoroon said: Should be. I've seen listings for heatsinks designed around the MSI P5200 for the TM, so I would believe any P5200 would work. Okay, thanks. Would I need custom drivers or can I download official drivers?
Tenoroon Posted May 28, 2023 Posted May 28, 2023 1 minute ago, jcordero said: Okay, thanks. Would I need custom drivers or can I download official drivers? That's something I couldn't answer but intuition says normal drivers will work. The P5200 is Pascal so I can't see why normal drivers won't work. 1 Clevo P870TM-G: Core i7 8700k @ 4.8ghz | Clevo RTX 2070 Super | 32gb HyperX DDR4 @ 3200mhz | 17" 1440p 120hz B173QTN01.0 Screen | 256gb Samsung 850 EVO | 500gb WD Blue SSD | Prema BIOS Alienware 17 R1: Core i7 4710mq @ 3.619ghz 741 CBR15 (834 CBR15 @ 4.213ghz) | Dell GTX 860m | 16gb HyperX DDR3L @ 2133mhz | 17" 3D 120hz LTN173HT02-T01 Screen | 256gb mSATA SSD Asus Zephyrus G14: Ryzen 7 4800hs @ 4.2ghz | GTX 1650 | 16gb DDR4 @ 3200mhz | 14" 120hz LM140LF1F01 Screen | 512gb NVME SSD
runix18 Posted May 30, 2023 Posted May 30, 2023 On 5/28/2023 at 7:19 PM, jcordero said: Okay, thanks. Would I need custom drivers or can I download official drivers? No custom drivers but definitely an inf mod. Desktop - MSI X670E Tomahawk Wifi (cheap Ebay mobo that I fixed) | AMD 9800X3D | 64GB Corsair Vengeance RGB DDR5 6000MHz CL30 Dual Channel Kit | MSI RTX 4070TI Suprim X | Alienware 27 AW2724DM 2K 165 Hz Gsync | Samsung 990 Pro Nvme - Boot | Other various storage | Windows 11 Enterprise x64 SOLD - Clevo P870DM-G | i9-9700K 4.5 Ghz on all cores (-50 mv undervolted) | 32GB Hyper X Black 2666MHz | Clevo RTX 2080 3.1b undervolted for better temp 1905Mhz @881 mv | AUO B173HAN03.1 144hz Gsync | Samsung 980 NVME | Dsanke TM BIOS - Chujoi13 adapted based on needs | Network Card: Intel AX210-AX | Windows 10 Pro x64
Bullit Posted June 1, 2023 Posted June 1, 2023 Why you do want to do that, VRAM? This is the score/number of benchmarks in Blender Cycles rendering GPU this is an advanced render engine that exploits the RTX cards. NVIDIA Quadro P5200 605.45 2 NVIDIA GeForce GTX 1080 618.04 493 These are obviously very low values for today. My 3060 laptop does 2615.
