TruenoG7 Posted June 14, 2023 Posted June 14, 2023 Hello, I recently installed my Nvidia Quadro RTX 3000 MXM, in my alienware 17 (2015), it turns out that it has a 3D EDP 120 hertz screen, when installing the rtx everything goes great, temperatures, and consumption, the strange thing comes When playing, the colors are sometimes distorted, giving a warm tone, and after about 20 or 30 minutes playing, the LCD screen turns off, and goes into some kind of loop where the audio repeats but does not completely block since the "CAPS LOCK" " and "NUM LOCK" button activate the led as if everything was going well, an external screen connects it and it doesn't post either, the only way is to force it to turn off, then I turn it on and everything is fine , until the same thing happens approximately time, if I only watch videos, browse or something like that the screen never turns off, any ideas what causes it? I am using the A14+ Bios, unlocked, it is in Full UEFI. By the way I have another, alienware 17 with LVDS, everything working correctly with the RTX 3000. I attach an image of the exact model of the screen and gpu that I have, it was previously installed on my alienware 18, working perfectly. ---Dell Precision M6700---, i7-4900MQ, Tesla M6, M6100/HD 8950M, 1920x1080p 6bits LVDS. ---Dell Precision M6800---, i7-4900MQ, Tesla M6, M6100/HD 8950M, 1920x1080p 6bits LVDS. ---Alienware M17x R2--, I7-940MX, HD 8970M Crossfire, M6100/HD 8950M, GTX 765M, 1920x1200P OC 75 Hzt. ---Alienware 17-- i7-4940MX, RTX 3000(LVDS),P3000, GTX 980M, 880M,860M, M6100/HD 8950M, 1080P, 120 Hz, 3D. --Alienware 18-- i7-4930MX, 32GB RAM 1866 MHz, RTX 4000, RTX 3000, P3000, M6100/HD 8950M, 1920x1080P. LCDOC 75 Hzt. (In use). ---Alienware M18x R2- i7-3940XM, 32GB RAM 1866 MHz, GTX 980M SLI, 1920x1080p 6bits OC 75 Hzt. Youtube Channel : https://www.youtube.com/channel/UCi0b4otJZHtUJePgIejiI4Q.
ssj92 Posted June 16, 2023 Posted June 16, 2023 If it works fine with LVDS panel in AW 17 and works fine in AW 18 then I assume it is some sort of conflict with the 120Hz panel. Does the 120hz panel work fine with older GPUs after 20-30 mins? 1 Alienware Area-51M : Intel Core i9-9900K @ 5.3Ghz | nVidia GeForce RTX 2080 | AX210 | Samsung 970 Evo+ Alienware M18x R2 : Intel Core i7 3920XM @ 4.7Ghz | nVidia GeForce RTX 3080 | AX210 | Samsung 980 PRO Alienware 18 : Intel Core i7 4930MX @ 4.5Ghz | nVidia Quadro RTX 5000 | AX210 | Samsung 980 NVMe More Laps: M14x | M14xR2 | M15x (980m) | M17xR2 (RTX 3000) | M17xR3 (WX 7100) | M18xR1 (RTX 5000) Precision 7520 (T1000) | 7720 (Tesla P6) BEAST Server: Intel Xeon W7-3465X 28 P-Cores | 2x nVidia RTX Titan | 128GB RDIMM | Intel Optane P5800X CS Studios YouTube: https://www.youtube.com/c/CSStudiosYT
TruenoG7 Posted June 19, 2023 Author Posted June 19, 2023 On 6/16/2023 at 1:45 AM, ssj92 said: If it works fine with LVDS panel in AW 17 and works fine in AW 18 then I assume it is some sort of conflict with the 120Hz panel. Does the 120hz panel work fine with older GPUs after 20-30 mins? Yes, with any other GPU everything works perfectly without color distortion. I currently put a P3000 on it, and I have used it for several days, everything is perfect. ---Dell Precision M6700---, i7-4900MQ, Tesla M6, M6100/HD 8950M, 1920x1080p 6bits LVDS. ---Dell Precision M6800---, i7-4900MQ, Tesla M6, M6100/HD 8950M, 1920x1080p 6bits LVDS. ---Alienware M17x R2--, I7-940MX, HD 8970M Crossfire, M6100/HD 8950M, GTX 765M, 1920x1200P OC 75 Hzt. ---Alienware 17-- i7-4940MX, RTX 3000(LVDS),P3000, GTX 980M, 880M,860M, M6100/HD 8950M, 1080P, 120 Hz, 3D. --Alienware 18-- i7-4930MX, 32GB RAM 1866 MHz, RTX 4000, RTX 3000, P3000, M6100/HD 8950M, 1920x1080P. LCDOC 75 Hzt. (In use). ---Alienware M18x R2- i7-3940XM, 32GB RAM 1866 MHz, GTX 980M SLI, 1920x1080p 6bits OC 75 Hzt. Youtube Channel : https://www.youtube.com/channel/UCi0b4otJZHtUJePgIejiI4Q.
