Hi!
Ive tried to install the 3.0 control center and it not works, when i start no error message nothing, it didnt appear in osd .
Someone has a fix for it or just let it go?
Your model doesn‘t support CC 3.0
you should install CC 2.0.
XMG Neo 17 (E24)  | 14900HX | 32GB (2X16) Kingston HyperX Fury DDR5@7200 CL36 | RTX4090 (+285/900) | QHD @240Hz G-Sync | 2x2TB Samsung 990 PRO | Killer WiFi 1675i | Oasis MK2 WC | Win 11 Home - TimeSpy
Clevo X170KM-G | 11700KF | 64GB (4x16) Crucial Ballistix DDR4@3066 CL14 | RTX3080 (+220/1650) | QHD @165Hz G-Sync | 1TB WD SN850X + 1TB WD SN750 | Intel AX200 WiFi | Win 11 Pro - TimeSpy
Then why the FB page say this :
Newest CLEVO Control Center 3.0 v1.34 are now available on our Server! Dedicated for newest models with Intel 9th and GTX, RTX Graphics Cards.
