raptorddd Posted January 2, 2024 Share Posted January 2, 2024 am using chris titus script and it set edge settings to disable.. on edge personal info save button is greyed out. cant find wich switch i need to activate to enable perosnal info. i assume chris titus as i see it does somthing with o^o shut up dell precision m4600 i7 2760QM 8GB ram MX500 crucial SSD 500GB. win 10 21H2 Link to comment Share on other sites More sharing options...
aldarxt Posted January 2, 2024 Share Posted January 2, 2024 3 hours ago, raptorddd said: am using chris titus script and it set edge settings to disable.. on edge personal info save button is greyed out. cant find wich switch i need to activate to enable perosnal info. i assume chris titus as i see it does somthing with o^o shut up `Maybe because there is no info in the boxes. The default is blank, try filling in some info and the save will light up 1 Clevo P870DM3-G i9-9900k-32.0GB 2667mhz-RTX3080+GTX1080 Alienware M18x R2 i7-3920xm-32GB DDR3-RTX 3000 Alienware M17x R4 i7-3940XM-16GB DDR3-RTX 3000 Alienware M17x R4 i7-3940XM 20GB DDR3-P4000 120hz 3D Precision m6700 i7-3840QM-16GB DDR3-GTX 970M Precision m4700 i7-3840QM-16GB DDR3-T2000M HP ZBook 17 G6 i7 9850H-32GB DDR4-RTX4000maxQ GOBOXX SLM G2721-i7-10875H RTX 3000-32GB ddr4 Link to comment Share on other sites More sharing options...
raptorddd Posted January 2, 2024 Author Share Posted January 2, 2024 1 hour ago, aldarxt said: `Maybe because there is no info in the boxes. The default is blank, try filling in some info and the save will light up no. i already tried that... update a yes it activates once you complete all fields.. what i want is to show me email addresses so i dont have to type them... so what i can tell is. if clean install of windows 11. if you go to 3 dots perdonal info you can just fill email.. but after it updates edge you cant you must fill all fields... dell precision m4600 i7 2760QM 8GB ram MX500 crucial SSD 500GB. win 10 21H2 Link to comment Share on other sites More sharing options...
