Can someone tell me please what 14 inch gaming laptop that use external battery?
Actually I'm thinking of Alienware X14.
But, after seeing some review video on Youtube, this laptop is use battery which the location is inside the case.
I would like to ask also what smallest screen Alienware laptop is using external battery and what gaming laptop use AMD processor and AMD graphic adapter?
My budget is around US$3,000.
Thank you in advance
Are you talking about using an external battery bank like this? Those things are only designed to be used to top off a laptop's internal battery or when performing non-intensive tasks.
The X14 is the smallest Alienware laptop, and there are only a couple model in general that have AMD CPUs and GPUs, including one version of the Alienware M18, the Framework 16, and the Asus TUF A16 Advantage Edition.
  • 1 year later...
There aren’t really any 14″ gaming laptops with an external, swappable battery — everything, including the Dell XPS 14 9440 and Alienware X14, uses an internal one. If you want longer unplugged use, the only real option is pairing the laptop with a high-wattage power bank or portable power station. For AMD CPU + AMD GPU in a gaming laptop, you’ll need to look at “AMD Advantage” models, but most 14″ machines mix Ryzen CPUs with NVIDIA graphics.
Most 14" gaming laptops, including the Alienware X14, use internal batteries, not external ones. External or swappable batteris are no longer common i think. If you want AMD CPU + AMD GPU, you will need to look at slighlty larger models 14" or 16". In your $3000 budget, the Razer Blade 14 or ASUS ROG Zephrus G14 are top picks for compact, powerful gaming laptops.
  • 4 weeks later...
If you’re looking for a 14" gaming laptop with a removable/external battery, unfortunately none of the modern models offer that anymore. The Alienware x14, Zephyrus G14, Razer Blade 14 — all of them use internal batteries.
Alienware also doesn’t have any small-screen model with an external battery these days.
If you want an all-AMD machine, check out ASUS models with the Ryzen + Radeon (AMD Advantage) setup — solid performance and good thermals.
And honestly, with a $3,000 budget, you could go for something much stronger, like the MSI Raider GE78 HX 14VX — bigger, but way better cooling and performance.
