X170 Watercooling running 2 Years
rainer124
And u keep it for ur self all this time 2 great mods what a selfish man lol 🤣 🤣
For the results I think you could do better with more sophisticated mod I know u kept things simple as much u can from what a saw but nothing to say good job man good job
On Aliexpress, I saw a special radiator for this laptop model that can be used for both water cooling and just air mode, but of course it's always nice to do something like this with your own hands and it deserves special respect.
  • 4 months later...
Hi here is the 2 nd Colling system (2nd X170KM-G) the first one ist work 2 years..
This is only Wather cooling no air.
It is even stronger, more efficient than the first water cooling system. 3080 with 10900k, benchmarks still come with temperatures...
XMG Neo 17 (E24)  | 14900HX | 32GB (2X16) Corsair Vengeance DDR5@6600 CL30 | RTX4090 (+285/900) | QHD @240Hz G-Sync | 2x2TB Samsung 990 PRO | Killer WiFi 1675i | Oasis MK2 WC | Win 11 Home - TimeSpy
Clevo X170KM-G | 11700KF | 64GB (4x16) Crucial Ballistix DDR4@3066 CL14 | RTX3080 (+220/1650) | QHD @165Hz G-Sync | 1TB WD SN850X + 1TB WD SN750 | Intel AX200 WiFi | Win 11 Pro - TimeSpy
On 10/19/2024 at 1:25 AM, rainer124 said:
And ! Mr. MiRaGe you Time Spy  Score
Your Time Spy place will also be cracked by me in the future 😉
If this makes you happy - go ahead:)
2 hours ago, MiRaGe said:
And those temps are low already - the 3080 at stock helps a lot as it has 35W lower power consumption than the 2080s that this chassis was designed for.
In my opinion this is a very well balanced system and it also runs very quiet up to about 200W power consumption with only a little help from external cooling fans.
19 minutes ago, Maro97 said:
 the rainer124 score without gpu OC and shunt mod
36K firestrike graphics without GPU OC only in somebody's dream;)
