Csupati Posted June 14, 2024 Share Posted June 14, 2024 Hi! Somebody knows whats the distance of the bracket holes for the CPU? I know 2 are higher then the other 2 . Thinking about to get an MXM to PCIe adapter , and get rid of the heatsink, but then want to put an AIO or water block on the CPU , maybe AM3(96X48mm) or AM4 socket (90X54mm) maybe close enough. Clevo P751TM1-G 8700K/16GB/GTX 1080@120W/1.5TB/FHD 144 G-Sync/ Asus PG279Q Link to comment Share on other sites More sharing options...
