M18R2 Panel Upgrade
On 8/30/2024 at 7:45 AM, dickcheneyx said:
Is there any way to upgrade the "okay" panels on the current M18R2 ? I know years back on my m18x it was possible (obviously making sure it's within spec).
Thanks!
Probably, but the panels don't come out as easily as they used to either.  They are two sided taped in, and the bezels don't come off very easily.  You would risk damaging the panel or breaking the bezel if you are not super careful.  When they do warranty replacements on the screens now they just send a whole screen and top lid and it all goes on in one piece.  While it's not impossible it's just going to be a lot more difficult.  You will very likely need to get new tape to apply if you get the screen out.
Alienware M18R2 | i9 14900hx | RTX4090 | 64GB DDR5
Alienware Area51m | i9 9900k | RTX2080 | 64GB DDR4
Alienware M15R5 | R9 5900hx | RTX3070 | 32GB DDR4
Alienware 17R4 | i7 7820HK | GTX1080 | 32GB DDR3 ( Dead, RIP )
Alienware Aurora R13 | i7 12700k | RTX3070Ti | 32GB DDR4
