emcze Posted September 28, 2024 Share Posted September 28, 2024 Hi, I bought MMX to NVMe adapter and new NVMe 2T Samsung 990PRO version with heatsink ( because I had 20% discount it was cheaper than standard ). Now I know that Heatsink version is too high for M18x. and I need to remove heatsink and after connected I have problem. System started with disk visible in system: I replaced Steam library to new NVMe drive and start play. All game had lags with low FPS. I replaced Steam library to old SSD but still was the same. I checked FurMark and FPS were low. Usually connented to AC power I have 85 FPS, on battery I have only 6 FPS... with NVMe and AC Power I had only 15 FPS. I tried find problem and I found it in power on my RTX. GPU-Z with full GPU load showed me very low power on GPU. I removed NVMe and everything were good: After installed NVMe one more time still the same - low power, low FPS. To fast replace disk I modified a little palm rest and now I need only remove keyboard Now tell me, WTF ?? Where is a pronlem ?? 1) I need change something in BIOS 2) Samsung 990PRO 2T drain to much power for my power supply and I need to replace it with other one ( I have few NVMe in my home serwer ) 3) My power supply 240W is too weak and I need to use 330W from SLI model I'm away from home ( 3 months in hospital and I'm only in half time ) and another disk can check when I back but maybe you use yours disk with 240W PS. Like always please HELP ME !!! 🙂 Alienware M18X R2 - i7-3940XM@4.5Ghz - Quadro RTX 3000 Alienware M17X R4 - i7-3740QM - Quadro P4000 Alienware M17X R4 - i7-3610QM - Quadro P4000 Alienware 13 R3 - i7-7700HQ - GTX 1050Ti Link to comment Share on other sites More sharing options...
nforce4max Posted September 28, 2024 Share Posted September 28, 2024 Power draw in this case shouldn't be the issue however running that without any cooling isn't a good idea at all even with the cheap crap out there. I would take a look to see what the gpu is running with in terms of pci-e lanes and if it is running at 3.0 spec etc beyond that is anyone's guess unless someone with some experience with this adapter comes forward. Link to comment Share on other sites More sharing options...
emcze Posted September 28, 2024 Author Share Posted September 28, 2024 29 minutes ago, nforce4max said: running that without any cooling isn't a good idea at all even with the cheap crap out there 990PRO... 200 USD is not cheap, I know few 2T about 100 USD 🙂 I use Samsung Magician and after copy 1T to the disk still was about 47 C. Heatsink is not a problem, I will use some copper plate when back home. Problem is low power on RTX. Alienware M18X R2 - i7-3940XM@4.5Ghz - Quadro RTX 3000 Alienware M17X R4 - i7-3740QM - Quadro P4000 Alienware M17X R4 - i7-3610QM - Quadro P4000 Alienware 13 R3 - i7-7700HQ - GTX 1050Ti Link to comment Share on other sites More sharing options...
emcze Posted October 8, 2024 Author Share Posted October 8, 2024 I ordered new 970 EVO Plus and situation is the same. Max. FTP about 17 and GPU power draw about 18W with SSD in adapter. Wrong adapter ?? not enought PS ( 240W ) if I have active 2 MXM slot ?? I saw that my battery indicator shows connected PS but description shows only battery state without charging and alll time is the same battery percentage. Alienware M18X R2 - i7-3940XM@4.5Ghz - Quadro RTX 3000 Alienware M17X R4 - i7-3740QM - Quadro P4000 Alienware M17X R4 - i7-3610QM - Quadro P4000 Alienware 13 R3 - i7-7700HQ - GTX 1050Ti Link to comment Share on other sites More sharing options...
aldarxt Posted October 8, 2024 Share Posted October 8, 2024 6 hours ago, emcze said: I ordered new 970 EVO Plus and situation is the same. Max. FTP about 17 and GPU power draw about 18W with SSD in adapter. Wrong adapter ?? not enought PS ( 240W ) if I have active 2 MXM slot ?? I saw that my battery indicator shows connected PS but description shows only battery state without charging and alll time is the same battery percentage. The m18xr2 I always use 330w adapter no matter what. The 17x's sometimes I use a 240w but try to use 330w if I am benching or gaming. Since you're using 2nd gpu slot I would try only 330w 1 Clevo P870DM3-G i9-9900k-32.0GB 2667mhz-RTX3080+GTX1080 Alienware M18x R2 i7-3920xm-32GB DDR3-RTX 3000 Alienware M17x R4 i7-3940XM-16GB DDR3-RTX 3000 Alienware M17x R4 i7-3940XM 20GB DDR3-P4000 120hz 3D Precision m6700 i7-3840QM-16GB DDR3-GTX 970M Precision m4700 i7-3840QM-16GB DDR3-T2000M HP ZBook 17 G6 i7 9850H-32GB DDR4-RTX4000maxQ GOBOXX SLM G2721-i7-10875H RTX 3000-32GB ddr4 Link to comment Share on other sites More sharing options...
emcze Posted October 22, 2024 Author Share Posted October 22, 2024 I bought new, originall 330W power suplly. BIOS shows 330W. When I connected NVMe disk ( no mater 970 EVO Plus or 990 PRO ) GPU Power Draw is on normall level. Problem is still with speed, all time 3 x 1. Software, driver or adapter problem ?? Alienware M18X R2 - i7-3940XM@4.5Ghz - Quadro RTX 3000 Alienware M17X R4 - i7-3740QM - Quadro P4000 Alienware M17X R4 - i7-3610QM - Quadro P4000 Alienware 13 R3 - i7-7700HQ - GTX 1050Ti Link to comment Share on other sites More sharing options...
