9 hours ago, raptorddd said:
why not use nvcleanstall it has option to add your card with only a few clicks.
Its sometimes has bugs, its write it but the game is glitching, or with one game is working and the other is not, dont know why, I dont like nvclean install.
On 10/1/2023 at 2:47 AM, Csupati said:
what laptop you have ?
You only need to mod 1 inf file and 3or 4 rows
For Dell/Alienware - nvdmig.inf
Clevo - nvcvig
Msi - nvmiig
Then go for the bottom and pick one of the GTX 1060 listings
Example
original NVIDIA_DEV.1C60.07C2.1028 = "NVIDIA GeForce GTX 1060"
your modded will be NVIDIA_DEV.1C60.0551.1028 = "NVIDIA GeForce GTX 1060"
Then search for 07C2 with 1C60 like:
original : %NVIDIA_DEV.1C60.07C2.1028% = Section164, PCI\VEN_10DE&DEV_1C60&SUBSYS_07C21028
your modded will be %NVIDIA_DEV.1C60.0551.1028% = Section164, PCI\VEN_10DE&DEV_1C60&SUBSYS_05511028
everywhere you find 1C20.0771 repalce with 1C20.0551 thats simple
If you are done with editing the inf file, restart the laptop in driver signature enforcment off and istall the driver. But drop me a dm what driver version you want to install and i will edit for you .
Mine is the Alienware m17x r4.
The relevant lines are:
NVIDIA_DEV.1B83 = "NVIDIA GeForce GTX 1060 6GB"
NVIDIA_DEV.1C03 = "NVIDIA GeForce GTX 1060 6GB"
NVIDIA_DEV.1C06 = "NVIDIA GeForce GTX 1060 6GB"
%NVIDIA_DEV.1B83%           = Section048, PCI\VEN_10DE&DEV_1B83
%NVIDIA_DEV.1C03%           = Section048, PCI\VEN_10DE&DEV_1C03
%NVIDIA_DEV.1C06%           = Section048, PCI\VEN_10DE&DEV_1C06
I understand that I need to change to:
NVIDIA_DEV.1C60 = "NVIDIA GeForce GTX 1060 6GB"
%NVIDIA_DEV.1C60%           = Section048, PCI\VEN_10DE&DEV_1C60
Is that correct?
Thanks!
Is that correct?
Thanks!
Pick only one row from this NVIDIA_DEV.1B83 = "NVIDIA GeForce GTX 1060 6GB"
and edit to this :NVIDIA_DEV.1C60 = "NVIDIA GeForce GTX 1060 6GB"
and from this: %NVIDIA_DEV.1B83%           = Section048, PCI\VEN_10DE&DEV_1B83
to this :%NVIDIA_DEV.1C60%           = Section048, PCI\VEN_10DE&DEV_1C60
The other 1060 rows can keep to stock it has no effect. No need to edit all 1060 just pick one replace it.
But other than that its okay. I allways edit the closest one to the original like in your case 1C06 ---> 1C60
