There is a lot of talk going on regarding this topic. And i cannot get my head around it.
"The current mobile CPU line from Intel is just bad, AMD is much better."
Is it true, that only the HX models are affected by the bad overall performance or there much more to it? So just use an H model and you are fine? Or has AMD finally found a way to built better mobile CPU than Intel? Ryzen 7/9 are hyped for their energy efficiency and performancewise.
Whats your opinion on this?
2017 Clevo Laptop, TuxedoOS/Win11
Basically you should ditch the complete 13th and 14th gen Intel CPU (crashes, bugs and heat) and go back to 12th gen Alder lake or wait for the new mobile lineup in 2025.
