kBoltzmann Posted May 18, 2025 Posted May 18, 2025 Hi everyone, I recently bought a refurbished Dell XPS 15 9520 from a professional seller in Germany (1-year warranty, 30-day return policy). Specs: i7-12700H 64 GB RAM 1 TB SSD Intel + NVIDIA graphics (RTX 3050) Battery: 56 Wh (original config, not upgraded) I’ve noticed the battery life is way below expectations. Here's what I tested: Started at 100% battery at 13:12 Light use: YouTube, Prime Video, web browsing At 15:18, I was at 51% Started a Steam + game download (22 GB) (just download, not playing) By 16:03, battery hit 5% → Total runtime: about 3 hours I’ve already applied power-saving tweaks on Windows: Set to best power efficiency Disabled NVIDIA GPU for browser/media apps Wi-Fi in power-save mode Brightness around 50% TLP/powertop considered for Linux Battery report shows: Design capacity: 54,891 mWh Full charge capacity: 46,786 mWh (~15% wear) This wear seems acceptable for a used device, but the battery life is just too short, even with light load. I was hoping for 5–6h minimum. My options now are: Ask the seller to replace the battery (possibly with the 86 Wh one) Replace it myself (I'm willing if it's worth it) Try Linux/Ubuntu to gain better runtime (but wear remains) Return the laptop entirely Questions: Anyone using an XPS 15 9520 with either battery config? What’s your real-world battery life? Is 3h normal for a 56 Wh battery with ~15% wear? Would you recommend swapping in an 86 Wh? Any known issues with thermals or fit in this model? Thanks in advance for any advice — especially if you’ve dealt with battery upgrades or dual-boot setups!
