Hi, all. I'm... contemplating xvision cards for kicks. One thing standing in the way though is displays; I currently use a 120hz panel with an msi 1070. I have a 60hz panel on hand but for some god awful reason I can't find its original display cable (the spec name for which I can't recall... the one that isn't edp... lvds maybe? Going with it for the sake of brevity).
Other than buying another M17x R4 and cannibalizing it (not unrealistic - abused ones have been showing up on facebook marketplace with some frequency... and a spare mobo... and a working 680m for recovery operations... wouldn't be a bad idea at this point), where would one source an lvds cable? The edp cable is incompatible with the lvds screen and wouldn't fit in the lvds port on the motherboard, right?
AW M18 R1 | i9-13900HX | RTX4090 | 64GB DDR5
AW M17XR4 | i7-3940XM | GTX1070 | 32GB DDR3
AW M15X | i7-940XM | GTX970m | 16GB DDR3
Formerly Schurke of NBR and TechInferno
Hi,
I may help you, I found my old 60hz, but salty with mildew (I think there was to much humidity in storage.)
if I can’t clean it, I could ship you the
cable, which is ok and clean 👍
[update] cleaning failed. The I can provide the cable, let me now if you still need it.
Edited by El_gohan
Parts People have them for $10 plus postage.
https://www.parts-people.com/index.php?action=item&id=10814
On 5/27/2025 at 5:47 AM, El_gohan said:
Hi,
Very generous offer, @El_gohan! That said, I'll see if I can't get a fresh one from parts people first -- I... totally forgot about them. Good call, @Maxware79
