ShifflyTheSHO Posted October 10, 2025 Posted October 10, 2025 (tl;dr, are the edp ports limited to two lanes?) Okay so here me out… So last week I managed to acquire two Clevos with the 1060 6GB, but they both had busted screens that I replaced on both with some N156KME screens that are 1440p and 165hz… but the edp cables were needing replaced so I ordered some that match 40pin female to 0.5mm 40pin male, but my main wuestion really is why am I not able to get a display even with a minitor plugged in? Does the 40pin edp port on these P650s only support 2lanes because they initially hooked up to only that 30pin screen? It was also an N156xxx, so I figured it would work out, but I have no display with the edp port plugged in or unplugged with either Haswell or Roswell (Sky Lake?), so does anybody have a viable solution to get these things to POST? I’ve messed with RAM and the CMOS, held the power button without battery or done the fn + D for 20 seconds…. What should I try next? I think I had them boot up previously, but I don’t remember, lol
ShifflyTheSHO Posted October 10, 2025 Author Posted October 10, 2025 One oh them displays when windows is booted up, but I’ll have to reset it to see if I can get a different refresh rate to take. The screens were only like, $20 a piece do to slight blemishes. Does Clevo use a particular pinout on that eDP connector? Do we have a 4lane eDP cable?
ShifflyTheSHO Posted October 24, 2025 Author Posted October 24, 2025 Turns out my LP156wf6(sp)(p2) that I ordered is slightly different somehow than the LP156WF6(sp)(b1) that came with the Clevos… turns out eDP connectors are all wited differently so its anyones guess work who or which screen is going to do what with whom.
