papjco32 Posted February 5 Posted February 5 Hey all, I have Sager p775dm3 that is dsanke bios modded with 9900k and 32gb ram.  First question is: The GTX 1080 in it under light loads will artifact as seen in the picture. If you reset the video driver using the windows shortcut it will come back. I can't get it to do it under full load, only light loads youtube web browsing office etc. Any ideas on what this could be or how to test?  Second question: I bought a for parts EVOC p775dm3 and the seller says it doesn't turn on (no light, nothing). How is the reliability of these motherboards? I haven't heard anything bad so I'm guessing bad bios, wrong charger or possible lack of RAM during testing? I got it for a good deal so not too worried if mobo doesn't work.  If you want to look at the one I bought: https://www.ebay.com/itm/206049322311  Thanks for any help,  papjco  IMG_0415.HEIC
