jonv8944s Posted June 26, 2024 Share Posted June 26, 2024 Ahhh thats exactly what I needed... Ok I will try it tomorrow, but yes, I was missing that LEGACY Option Rom enabled, because I never saw that intel Rapid Storage Technlogy menu anymore after the unlocked bios install. This helps, but I will tackle it tomorrow, not in the mood for it tonight. I REALLY appreciate all the help !! Link to comment Share on other sites More sharing options...
emcze Posted June 26, 2024 Share Posted June 26, 2024 Hi, I pick up my RTX. Round 1: Installed after start GPU is visible in BIOS but windows device meneger show me video controller 3w what now ?? i don't have any information about this device, only code 28 and can't edit driver. Alienware M18X R2 - i7-3940XM@4.5Ghz - Quadro RTX 3000 Alienware M17X R4 - i7-3740QM - Quadro P4000 Alienware M17X R4 - i7-3610QM - Quadro P4000 Alienware 13 R3 - i7-7700HQ - GTX 1050Ti Link to comment Share on other sites More sharing options...
emcze Posted June 26, 2024 Share Posted June 26, 2024 Round 2: I tried to install RTX Driver but " device is not present " Second try and this time I copied Nvidia Driver to another location. From directory with drivers I manualy installed nv_dispwi.inf. In Device Meneger I "update driver" and chose GRAPHIC DRIVER / NVIDIA / QUADRO RTX3000 ( was present after installed nv_dispwi.inf ) and.... my new Quadra RTX3000 is on my system 🙂 I copied BIOS here if you want to compare. https://www.techpowerup.com/vgabios/268486/268486 Alienware M18X R2 - i7-3940XM@4.5Ghz - Quadro RTX 3000 Alienware M17X R4 - i7-3740QM - Quadro P4000 Alienware M17X R4 - i7-3610QM - Quadro P4000 Alienware 13 R3 - i7-7700HQ - GTX 1050Ti Link to comment Share on other sites More sharing options...
emcze Posted June 26, 2024 Share Posted June 26, 2024 Round 3: I modified nv_dispwi.inf for my RTX 3000 and installed with "Disabled driver signature enforcement"... with fully succes ! 🙂 🙂 🙂 Alienware M18X R2 - i7-3940XM@4.5Ghz - Quadro RTX 3000 Alienware M17X R4 - i7-3740QM - Quadro P4000 Alienware M17X R4 - i7-3610QM - Quadro P4000 Alienware 13 R3 - i7-7700HQ - GTX 1050Ti Link to comment Share on other sites More sharing options...
emcze Posted June 28, 2024 Share Posted June 28, 2024 Liquid metal works with RTX 3000. "Shadow of the Tomb Rider" with all setings at Ultra gives me over 40fps with GPU temp about 60-70 C I have problem with M17X R4, I installed unlocked BIOS without problem but I changed from Legacy to UEFI and... M17X now only power on and power off, power on and power off, power on and power off, power on and power off........... After removed CMOS battery I have 5 beeps but after restarted still power on and power off, power on and power off, power on and power off, power on and power off.... It looks like "BIOS will not allow POST to complete without TPM handshake with original TPM Windows 10 or TPM Windows 11 (C:) boot disk" and "If your motherboard's security feature refuses to be unlocked or has been corrupted, a new motherboard is your only option." Maybe another solution ?? here is link Alienware M18X R2 - i7-3940XM@4.5Ghz - Quadro RTX 3000 Alienware M17X R4 - i7-3740QM - Quadro P4000 Alienware M17X R4 - i7-3610QM - Quadro P4000 Alienware 13 R3 - i7-7700HQ - GTX 1050Ti Link to comment Share on other sites More sharing options...
ssj92 Posted June 28, 2024 Author Share Posted June 28, 2024 Do you see AW logo and can boot to BIOS before it turns off? Alienware Area-51 18 : Intel Core Ultra 9 275HX @ ??? | nVidia GeForce RTX 5090 | BE200 | 1TB Gen5 9100 PRO Alienware Area-51M : Intel Core i9-9900K @ 5.3Ghz | nVidia GeForce RTX 2080 | AX210 | Samsung 970 Evo+ Alienware M18x R2 : Intel Core i7 3920XM @ 4.7Ghz | nVidia GeForce RTX 3080 | AX210 | Samsung 980 PRO Alienware 18 : Intel Core i7 4930MX @ 4.5Ghz | nVidia Quadro RTX 5000 | AX210 | Samsung 980 NVMe More Laps: M14x | M14xR2 | M15x (980m) | M17xR2 (RTX 3000) | M17xR3 (WX 7100) | M18xR1 (RTX 5000) BEAST Server: Intel Xeon W7-3465X 28 P-Cores | 2x nVidia RTX Titan | 128GB RDIMM | Intel Optane P5800X CS Studios YouTube: https://www.youtube.com/c/CSStudiosYT Link to comment Share on other sites More sharing options...
emcze Posted June 28, 2024 Share Posted June 28, 2024 1 minute ago, ssj92 said: Do you see AW logo Hi. No. Only keyboard blink, fan start, alien logo fast blinking and power off, after next 1 sec. the same till I disconnect battery. Alienware M18X R2 - i7-3940XM@4.5Ghz - Quadro RTX 3000 Alienware M17X R4 - i7-3740QM - Quadro P4000 Alienware M17X R4 - i7-3610QM - Quadro P4000 Alienware 13 R3 - i7-7700HQ - GTX 1050Ti Link to comment Share on other sites More sharing options...
jonv8944s Posted June 29, 2024 Share Posted June 29, 2024 On 6/26/2024 at 3:46 PM, emcze said: Round 2: I tried to install RTX Driver but " device is not present " Second try and this time I copied Nvidia Driver to another location. From directory with drivers I manualy installed nv_dispwi.inf. In Device Meneger I "update driver" and chose GRAPHIC DRIVER / NVIDIA / QUADRO RTX3000 ( was present after installed nv_dispwi.inf ) and.... my new Quadra RTX3000 is on my system 🙂 I copied BIOS here if you want to compare. https://www.techpowerup.com/vgabios/268486/268486 1. Would it be possible for you to give a step-by-step for this? I am at this phase right now too, and I dont want to mess anything up. I am getting this error: 2. Also how are you guys running windows 11 when it states we dont have the right hardware on our Alienware M18x r2 to run windows 11? I'd love to move my sons pc up to windows 11, but when I tried before it said hardware didnt support it. Any help? Link to comment Share on other sites More sharing options...
aldarxt Posted June 29, 2024 Share Posted June 29, 2024 19 minutes ago, jonv8944s said: 1. Would it be possible for you to give a step-by-step for this? I am at this phase right now too, and I dont want to mess anything up. 2. Also how are you guys running windows 11 when it states we dont have the right hardware on our Alienware M18x r2 to run windows 11? I'd love to move my sons pc up to windows 11, but when I tried before it said hardware didnt support it. Any help? Use RUFUS and Win 11 ISO, there is a guide, on RUFUS site for burning to thumb drive, then on win 10 click setup.exe and should install, I prefer not to set with user account so I can install on any PC 1 Clevo P870DM3-G i9-9900k-32.0GB 2667mhz-RTX3080+GTX1080 Alienware M18x R2 i7-3920xm-32GB DDR3-RTX 3000 Alienware M17x R4 i7-3940XM-16GB DDR3-RTX 3000 Alienware M17x R4 i7-3940XM 20GB DDR3-P4000 120hz 3D Precision m6700 i7-3840QM-16GB DDR3-GTX 970M Precision m4700 i7-3840QM-16GB DDR3-T2000M HP ZBook 17 G6 i7 9850H-32GB DDR4-RTX4000maxQ GOBOXX SLM G2721-i7-10875H RTX 3000-32GB ddr4 Link to comment Share on other sites More sharing options...
emcze Posted June 29, 2024 Share Posted June 29, 2024 35 minutes ago, jonv8944s said: 1. Would it be possible for you to give a step-by-step for this? If you download this file nv_dispwi.inf and click right button on it, and manually install it your RTX should works. Try to download Furmark 3D and check it. but if you have full Nvidia driver you should do this: ( say hallo to @ssj92 🙂 ) 1 1 Alienware M18X R2 - i7-3940XM@4.5Ghz - Quadro RTX 3000 Alienware M17X R4 - i7-3740QM - Quadro P4000 Alienware M17X R4 - i7-3610QM - Quadro P4000 Alienware 13 R3 - i7-7700HQ - GTX 1050Ti Link to comment Share on other sites More sharing options...
jonv8944s Posted June 29, 2024 Share Posted June 29, 2024 Are these temps too high?! Ugh 😩 Link to comment Share on other sites More sharing options...
emcze Posted June 29, 2024 Share Posted June 29, 2024 45 minutes ago, jonv8944s said: Are these temps too high?! Ugh I have about 77 - 80 in hotspot. But when I play with video settings on ultra I have obout 60. Furmark is killer not realustic test. 1 Alienware M18X R2 - i7-3940XM@4.5Ghz - Quadro RTX 3000 Alienware M17X R4 - i7-3740QM - Quadro P4000 Alienware M17X R4 - i7-3610QM - Quadro P4000 Alienware 13 R3 - i7-7700HQ - GTX 1050Ti Link to comment Share on other sites More sharing options...
jonv8944s Posted June 29, 2024 Share Posted June 29, 2024 Any idea why mine is higher temps? I used kryonaut extreme. And new Thermal pads on what I thought were the important components on the GPU. Link to comment Share on other sites More sharing options...
emcze Posted June 29, 2024 Share Posted June 29, 2024 8 minutes ago, jonv8944s said: I used kryonaut extreme. I used conductonaut liquid metal. Alienware M18X R2 - i7-3940XM@4.5Ghz - Quadro RTX 3000 Alienware M17X R4 - i7-3740QM - Quadro P4000 Alienware M17X R4 - i7-3610QM - Quadro P4000 Alienware 13 R3 - i7-7700HQ - GTX 1050Ti Link to comment Share on other sites More sharing options...
emcze Posted June 29, 2024 Share Posted June 29, 2024 To check realistic temp run GPU-z and monit temp when play game with high settings. 1 1 Alienware M18X R2 - i7-3940XM@4.5Ghz - Quadro RTX 3000 Alienware M17X R4 - i7-3740QM - Quadro P4000 Alienware M17X R4 - i7-3610QM - Quadro P4000 Alienware 13 R3 - i7-7700HQ - GTX 1050Ti Link to comment Share on other sites More sharing options...
jonv8944s Posted June 29, 2024 Share Posted June 29, 2024 Btw again BIG THANK YOU So much to the 3 of you for making this work @emcze @ssj92 and the 3rd guy i forgot lol. system is up and running, I’ll tweak it for more performance later, just glad it all worked. What a pain in the 🫏. Link to comment Share on other sites More sharing options...
emcze Posted June 29, 2024 Share Posted June 29, 2024 42 minutes ago, jonv8944s said: BIG THANK YOU I only summary information from this thread. It was from smarter users than me. 1 1 Alienware M18X R2 - i7-3940XM@4.5Ghz - Quadro RTX 3000 Alienware M17X R4 - i7-3740QM - Quadro P4000 Alienware M17X R4 - i7-3610QM - Quadro P4000 Alienware 13 R3 - i7-7700HQ - GTX 1050Ti Link to comment Share on other sites More sharing options...
jonv8944s Posted June 29, 2024 Share Posted June 29, 2024 ugh, ok I took the advice on how to upgrade to windows 11, and now I am on windows 11 BUT the NVIDIA card is now not working.. ugh... (Now what do I do?) Link to comment Share on other sites More sharing options...
emcze Posted June 29, 2024 Share Posted June 29, 2024 31 minutes ago, jonv8944s said: the NVIDIA card is now not working.. ugh... (Now what do I do?) I had the same. On 6/26/2024 at 8:29 PM, emcze said: but windows device meneger show me video controller 3w what now ?? i don't have any information about this device, only code 28 and can't edit driver. Your RTX3000 now is named 3D Video Controller. What you need to do: Download file nv_dispwi.inf - I uploaded it few post earlier. Click right button on It and click install on menu. After "Driver was installed succesfull" go to the Device Meneger and click on 3D Video Display. Click update driver and use update nanualy from driver installed in system. Click Graphic Card after that Nvidia after that Quadro RTX3000. Will be information that this driver can be not correct for this device but click update. Now your 3D Video display will be RTX3000. 1 Alienware M18X R2 - i7-3940XM@4.5Ghz - Quadro RTX 3000 Alienware M17X R4 - i7-3740QM - Quadro P4000 Alienware M17X R4 - i7-3610QM - Quadro P4000 Alienware 13 R3 - i7-7700HQ - GTX 1050Ti Link to comment Share on other sites More sharing options...
jonv8944s Posted June 30, 2024 Share Posted June 30, 2024 I'm getting this error now: Link to comment Share on other sites More sharing options...
jonv8944s Posted June 30, 2024 Share Posted June 30, 2024 Also if anyone has 'updated' drivers for those 2 OTHER "!" devices, I'd love to know how to make those go away too: 1. Intel(r) Wireless Bluetooth(R) 2. NVIDIA Platform Controllers and Framework Any help on those will be appreciated as well! Link to comment Share on other sites More sharing options...
jonv8944s Posted June 30, 2024 Share Posted June 30, 2024 I MAY have fixed it, I did a DDU clean driver install and now its not giving me the error on the display adapter. About to reboot and see if the error comes back. well device error is gone, but now when i try to run a game or use nvidia control panel it crashes with this: Link to comment Share on other sites More sharing options...
emcze Posted June 30, 2024 Share Posted June 30, 2024 7 hours ago, jonv8944s said: but now when i try to run a game or use nvidia control panel it crashes with this: It means driver error. Try use earlier driver for RTX. Alienware M18X R2 - i7-3940XM@4.5Ghz - Quadro RTX 3000 Alienware M17X R4 - i7-3740QM - Quadro P4000 Alienware M17X R4 - i7-3610QM - Quadro P4000 Alienware 13 R3 - i7-7700HQ - GTX 1050Ti Link to comment Share on other sites More sharing options...
emcze Posted June 30, 2024 Share Posted June 30, 2024 I want to check your problem... I used DDU cleaner. Removed all driver. Installed new RTX3000 driver and... have the same. Shadow of the Tomb Rider and Mad Max not working, system gave me blue screen. I hope tha system recovery point repair my computer 🙂 1 Alienware M18X R2 - i7-3940XM@4.5Ghz - Quadro RTX 3000 Alienware M17X R4 - i7-3740QM - Quadro P4000 Alienware M17X R4 - i7-3610QM - Quadro P4000 Alienware 13 R3 - i7-7700HQ - GTX 1050Ti Link to comment Share on other sites More sharing options...
jonv8944s Posted June 30, 2024 Share Posted June 30, 2024 You probably wont like my solution, its probably excessive, but I reinstalled windows 10 but used same new nvidia driver and bsod stopped and no more crashing when I play my kids fortnite game (which is the whole thing that started this upgrade lol) Also that’s too nice of you to try to reproduce my issue, I was worried it was a bad card for me, but if yours does the same thing now, I think you are right its a bad driver (when used with windows 11). It works fine on windows 10. Link to comment Share on other sites More sharing options...
