Guest Posted April 23, 2022 Posted April 23, 2022 Hello, I have a M17x R4 and two VGA cards: a GTX 980M and a GTX 680M (spare). I have the opportunity to get a cheap M17x R5 VGA heatsink (PN 0YP26V). Will it fit in a M17x R4 motherboard? Will it be any improvement in terms of heat dissipation regarding the original heatsink (PN 0MT1DN)? Thanks, Regards.
NNS_Max Posted April 23, 2022 Posted April 23, 2022 Out of interest, where did you get your 980m? I've been trying to purchase one for the M17xR4 but the last 3 from China, as well as a local 880m in the UK, have all arrived faulty.
Tenoroon Posted April 23, 2022 Posted April 23, 2022 34 minutes ago, NNS_Max said: Out of interest, where did you get your 980m? I've been trying to purchase one for the M17xR4 but the last 3 from China, as well as a local 880m in the UK, have all arrived faulty. I have a working 980m pulled from a Clevo P870DM, as a matter of fact, I'm using it right now. Would you be interested at all? Clevo P870TM-G: Core i7 8700k @ 4.8ghz | Clevo RTX 2070 Super | 32gb HyperX DDR4 @ 3200mhz | 17" 1440p 120hz B173QTN01.0 Screen | 256gb Samsung 850 EVO | 500gb WD Blue SSD | Prema BIOS Alienware 17 R1: Core i7 4710mq @ 3.619ghz 741 CBR15 (834 CBR15 @ 4.213ghz) | Dell GTX 860m | 16gb HyperX DDR3L @ 2133mhz | 17" 3D 120hz LTN173HT02-T01 Screen | 256gb mSATA SSD Asus Zephyrus G14: Ryzen 7 4800hs @ 4.2ghz | GTX 1650 | 16gb DDR4 @ 3200mhz | 14" 120hz LM140LF1F01 Screen | 512gb NVME SSD
Tenoroon Posted April 23, 2022 Posted April 23, 2022 1 hour ago, whitewhale2 said: Hello, I have a M17x R4 and two VGA cards: a GTX 980M and a GTX 680M (spare). I have the opportunity to get a cheap M17x R5 VGA heatsink (PN 0YP26V). Will it fit in a M17x R4 motherboard? Will it be any improvement in terms of heat dissipation regarding the original heatsink (PN 0MT1DN)? Thanks, Regards. Yes, it should fit with the M17x R4 motherboard, @Maxware79should be able to ensure if it fits, he knows a lot. There won't be much difference since they have a very similar mass and both have 3 heatpipes. There is a 5 pipe custom one on Ebay that I used in my Ranger and it kept my power hungry 1070 at under 65C all the time, I'd recommend that if you want to do a bit of overclocking or want to keep your GPU cool. Clevo P870TM-G: Core i7 8700k @ 4.8ghz | Clevo RTX 2070 Super | 32gb HyperX DDR4 @ 3200mhz | 17" 1440p 120hz B173QTN01.0 Screen | 256gb Samsung 850 EVO | 500gb WD Blue SSD | Prema BIOS Alienware 17 R1: Core i7 4710mq @ 3.619ghz 741 CBR15 (834 CBR15 @ 4.213ghz) | Dell GTX 860m | 16gb HyperX DDR3L @ 2133mhz | 17" 3D 120hz LTN173HT02-T01 Screen | 256gb mSATA SSD Asus Zephyrus G14: Ryzen 7 4800hs @ 4.2ghz | GTX 1650 | 16gb DDR4 @ 3200mhz | 14" 120hz LM140LF1F01 Screen | 512gb NVME SSD
Maxware79 Posted April 26, 2022 Posted April 26, 2022 The heatsinks are very close but not quite the same. One is slightly longer than the other. I have heard someone putting a 17 R1 heatsink into an M17x R4 so maybe it works that way but not the other. I can do a comparison photo when I get a chance to show the slight difference. 1 Alienware Aurora R15 - i9-13900KF - RTX 4090 - 32GB DDR5 Alienware X51 - i7-3770 - GTX 1060 - 16GB 1600Mhz DDR3 Alienware M17x R3 - i7-2760QM - GTX 580M - 16GB 1600Mhz DDR3 Alienware Area 51 ALX - i7-975 Extreme - GTX 980 - 16GB 1600Mhz DDR3 Alienware Aurora R2 - i7-3770K - GTX 670FTW - 16GB 1600Mhz DDR3 Alienware Aurora R4 ALX - i7-3930K - GTX 1060 - 16GB 1600Mhz DDR3 Alienware Aurora R4 ALX - i7-3930K - GTX 670FTW - 16GB 1600Mhz DDR3
aldarxt Posted April 26, 2022 Posted April 26, 2022 On 4/23/2022 at 6:46 PM, whitewhale2 said: Hello, I have a M17x R4 and two VGA cards: a GTX 980M and a GTX 680M (spare). I have the opportunity to get a cheap M17x R5 VGA heatsink (PN 0YP26V). Will it fit in a M17x R4 motherboard? Will it be any improvement in terms of heat dissipation regarding the original heatsink (PN 0MT1DN)? Thanks, Regards. I have been looking at 6 pipe heatsink and wondering if they really make a difference in dissipating the heat. If they make a difference the price would be worth it.?! Clevo P870DM3-G i9-9900k-32.0GB 2667mhz-RTX3080+GTX1080 Alienware M18x R2 i7-3920xm-32GB DDR3-RTX 3000 Alienware M17x R4 i7-3940XM-16GB DDR3-RTX 3000 Alienware M17x R4 i7-3940XM 20GB DDR3-P4000 120hz 3D Precision m6700 i7-3840QM-16GB DDR3-GTX 970M Precision m4700 i7-3840QM-16GB DDR3-T2000M HP ZBook 17 G6 i7 9850H-32GB DDR4-RTX4000maxQ GOBOXX SLM G2721-i7-10875H RTX 3000-32GB ddr4
