need help on making a script to set services to manual.
raptorddd
not sure where to start...
i want to have a script that would set useless services to manual.  one script that i used was chris titus essential tweaks. in the debloater. but it also disables some options or features i want..
so am wondering if can be done that i could use that part of the script only. i tried myself ( i have 0 knowledge but tought i could copy only that part and just create a new script) not sure if it needs more code to work. tried lit script but fails error access is denied.
so if it can be done and someone know how if you can please help..
thanks
dell precision m4600
i7 2760QM
8GB ram
MX500 crucial SSD 500GB.
win 10 21H2
Save the following in a .ps1 file for powershell and run it, replace with the services you wish to disable.
#requires -RunAsAdministrator
# comma seperated list of service names to set to manual
$servicestodisable = "Fax","GamingServicesNet"
# loop through each service and set to manual and stop the service.
Foreach ($service in $servicestodisable) {
    $s = Get-service $service
    $s | Set-service -StartupType Manual
    $s | stop-service
    $s | stop-service
thanks so i just add services here..
or here
$s = Get-service $service  on this last part $printspooler
i7 2760QM
8GB ram
win 10 21H2
or here
In the line with fax. Replace those with any services you want disabled.
