saturnotaku Posted May 5, 2022 Posted May 5, 2022 The app created by a group of enterprising coders has been revamped to provide even more functionality. Here's the full feature set: Full real custom Fan Curves! • Create a custom fan curve for each Power Mode • Decide the temperature points when the fan speeds will change • Decide what the fan speeds should be at each temperature point • The maximum allowed Fan Speed in the curve is dynamically determined based on Lenovo recommendations for your model • Stock Fan Curve settings are restored on exiting the application Switch Legion Power Modes Will also switch corresponding Windows Power Plans if they exist Windows Power Plan Control Choose whether switching the Legion Power Mode will also switch the corresponding Windows Power Plans if it exists. Some users may want to disable this behaviour if they use other tools to manage their Windows Power Plan switching events Turbo Mode Removes laptop control of the fans so they run at their factory maximum speeds. Only available in Discrete Graphics Mode (Hybrid Off). Hysteresis Determines how often LegionFanControl should check the current temperature before deciding to change fan speed or not Read the current Fan Speed Now in RPM values Fan acceleration speed Determines how quickly the fans accelerate or decelerate when it is time to change fan speeds. This feature is only available on 2021 and 2022 models Save custom fan curves and user settings Settings are auto-loaded at launch Launch at Start-up LegionFanControl can optionally automatically launch when you log in to Windows Start minimised LegionFanControl can optionally start minimised when launched List of supported and unsupported models, along with download links are available at the official website: LegionFanControl 1 1 Desktop: Ryzen 5 7600X3D | 32 GB RAM | Radeon RX 9070 GRE | 8 TB SSD | Windows 11 Lenovo Legion 5i: Core Ultra 7 255HX | 32 GB RAM | GeForce RTX 5070 | 1 TB SSD | Windows 11 Gigabyte Aorus 16X: Core i7-14650HX | 32 GB RAM | GeForce RTX 4070 | 1 TB SSD | Windows 11 Lenovo IdeaPad 5 Pro: Ryzen 5 5600U | 16 GB RAM | Radeon Graphics | 512 GB SSD | Windows 11 MacBook Neo: Apple A18 Pro | 8 GB RAM | 512 GB SSD | macOS
