TrantaLocked Posted October 13, 2022 Share Posted October 13, 2022 There are a few characteristics of a PWM signal from high to low like voltage, frequency and duty ratio. However, which of these characteristics are controlled by the motherboard? Is there a handshake that let's the display choose what it wants, or does the motherboard firmware force one set of values regardless of which display is installed? So for example, does the motherboard only control voltage level and the display handles the rest, or does the motherboard also control the frequency of the signal? Link to comment Share on other sites More sharing options...
Ishayin Posted October 16, 2022 Share Posted October 16, 2022 From the way Notebookcheck reviews are written, I've always been under the impression that the PWM controller is a part of the screen itself: https://www.notebookcheck.net/Why-Pulse-Width-Modulation-PWM-is-such-a-headache.270240.0.html  I had a quick look and found this thread which also seems to support this being the case: https://forums.tomsguide.com/threads/pwm-is-controlled-by-screen-or-motherboard.431490/  Link to comment Share on other sites More sharing options...
