TheQuentincc Posted January 29, 2022 Posted January 29, 2022 Hi, I'm looking to upgrade the display on my Precision 7550, the current eDP cable I got is only a 30 pin one but I need the 40 pins version of this cable, I can't find the UHD version of the eDP cable for the 7550, only 7750 and 7560 are available. Does someone have the 4k 7550 version and could share me the part number of the cable (behind the display) ? As for the display I still hesite between the Macbook "AUO B160QAN01.0" 3072*1920 60Hz display and the "BOE NE160QDM-NY1" 2560*1600 165Hz display, both can be found for pretty fair price (about 150) and they are both 16/10 Thanks for your help 😉 Desktop / I7 14700KF @5.4/4.5GHz 1.25v delidded / MSI Z690 Edge Wifi DDR4 / 32GB DDR4 B-die @4200c16 / RTX 3080 Ti MSI Trio Plus / Triple 27" 4k120 + 2*4k60 XPS 9500 / I7 10750H @3.2GHz all-core / 32GB DDR4 2400MHz / GTX 1650Ti 4GB @50W / 15.6" UHD / NVME / 86Wh Precision 7550 / I9 10885H @4.6GHz all-core / 32GB DDR4 2933MHz / Quadro RTX3000 6GB @80W / 15.6" FHD IPS 500nits / NVME / 95Wh I was once running an overclocked I7 3920XM @4.2GHz all-core (nvram edit) in a Dell Precision M6700 with 32GB 2133MHz DDR3L, a Quadro P4000 and a 4k eDP display (using 3d cable)
Ionising_Radiation Posted January 29, 2022 Posted January 29, 2022 1 hour ago, TheQuentincc said: Does someone have the 4k 7550 version and could share me the part number of the cable (behind the display) ? First post here, with a classic emoji The 7560 cable should be interchangeable with the 7550 (as should most of the other non-motherboard, non-GPU parts); in fact, my CMN 1080p 500-nit display is listed as a 7550 part. 1 hour ago, TheQuentincc said: and they are both 16/10 How do you plan to fit the 16:10 display onto the 7550, which has a 16:9 bezel?
Aaron44126 Posted January 29, 2022 Posted January 29, 2022 Likewise, I would think that the 7560 cable would work ... if the display port on the motherboard is the same and in the roughly the same position. I know you already have it but for anyone else who stumbles across this, the 7560 display+IR camera cable DPN is GDB55. https://www.nbrchive.net/forum.notebookreview.com/threads/precision-7560-7760-owners-thread.836381/page-77.html#post-11114355 Spoiler Apple MacBook Pro 16-inch, 2023 (personal) • Dell Precision 7560 (work) • Full specs in spoiler block below Info posts (Windows) — Turbo boost toggle • The problem with Windows 11 • About Windows 10/11 LTSC Spoiler Apple MacBook Pro 16-inch, 2023 (personal) M2 Max 4 efficiency cores 8 performance cores 38-core Apple GPU 96GB LPDDR5-6400 8TB SSD macOS 15 "Sequoia" 16.2" 3456×2234 120 Hz mini-LED ProMotion display Wi-Fi 6E + Bluetooth 5.3 99.6Wh battery 1080p webcam Fingerprint reader Also — iPhone 12 Pro 512GB, Apple Watch Series 8 Dell Precision 7560 (work) Intel Xeon W-11955M ("Tiger Lake") 8×2.6 GHz base, 5.0 GHz turbo, hyperthreading ("Willow Cove") 64GB DDR4-3200 ECC NVIDIA RTX A2000 4GB Storage: 512GB system drive (Micron 2300) 4TB additional storage (Sabrent Rocket Q4) Windows 11 Enterprise LTSC 2024 15.6" 3940×2160 IPS display Intel Wi-Fi AX210 (Wi-Fi 6E + Bluetooth 5.3) 95Wh battery 720p IR webcam Fingerprint reader Previous Dell Precision 7770, 7530, 7510, M4800, M6700 Dell Latitude E6520 Dell Inspiron 1720, 5150 Dell Latitude CPi
TheQuentincc Posted January 29, 2022 Author Posted January 29, 2022 Thanks for both response 🙂 5 hours ago, Ionising_Radiation said: How do you plan to fit the 16:10 display onto the 7550, which has a 16:9 bezel? 16" 16/10 Display share the same lenght as 15.6" 16/9, it's only the width that vary, it's gonna be very tight but I belive it's gonna works :), it will need to make some bezel adjustement/cuting Desktop / I7 14700KF @5.4/4.5GHz 1.25v delidded / MSI Z690 Edge Wifi DDR4 / 32GB DDR4 B-die @4200c16 / RTX 3080 Ti MSI Trio Plus / Triple 27" 4k120 + 2*4k60 XPS 9500 / I7 10750H @3.2GHz all-core / 32GB DDR4 2400MHz / GTX 1650Ti 4GB @50W / 15.6" UHD / NVME / 86Wh Precision 7550 / I9 10885H @4.6GHz all-core / 32GB DDR4 2933MHz / Quadro RTX3000 6GB @80W / 15.6" FHD IPS 500nits / NVME / 95Wh I was once running an overclocked I7 3920XM @4.2GHz all-core (nvram edit) in a Dell Precision M6700 with 32GB 2133MHz DDR3L, a Quadro P4000 and a 4k eDP display (using 3d cable)
