runix18 Posted January 30, 2023 Share Posted January 30, 2023 As per title, please help me find this vbios 86.04.80.00.23. Thank you. Desktop - MSI X670E Tomahawk Wifi (cheap Ebay mobo that I fixed) | AMD 7800X3D | 32 GB Trident Z5 Neo RGB 6000Mhz | MSI RTX 4070TI Suprim X | Alienware 27 AW2724DM 2K 165 Hz Gsync | Samsung 990 Pro Nvme - Boot | Other various storage | Windows 10 Pro x64 SOLD - Clevo P870DM-G | i9-9700K 4.5 Ghz on all cores (-50 mv undervolted) | 32GB Hyper X Black 2666MHz | Clevo RTX 2080 3.1b undervolted for better temp 1905Mhz @881 mv | AUO B173HAN03.1 144hz Gsync | Samsung 980 NVME | Dsanke TM BIOS - Chujoi13 adapted based on needs | Network Card: Intel AX210-AX | Windows 10 Pro x64 Link to comment Share on other sites More sharing options...
Frugfath3r Posted February 3, 2023 Share Posted February 3, 2023 Hello . What CLEVO system would you like it for might be able to pull it off one of mine Link to comment Share on other sites More sharing options...
ViktorV Posted February 3, 2023 Share Posted February 3, 2023 On 1/30/2023 at 6:51 PM, runix18 said: As per title, please help me find this vbios 86.04.80.00.23. Thank you. Hello! Why do you need him? Сlevo p870tm1-g 17.3 Fhd 300Hz i9-10980hk ES rtx3060. / Clevo x170smg 17.3 300Hz i9-10850k rtx2070super 32g ddr4 3200Mhz Gskill. / Clevo x170kmg 17.3 2k 165Hz i5-11600k rtx3080 32g ddr4 3200Mhz Hyper-X. Link to comment Share on other sites More sharing options...
Dzhon Posted February 3, 2023 Share Posted February 3, 2023 1 hour ago, ViktorV said: Привет! Зачем он тебе нужен? hello, because this bios comes with a shavoda, the card does not work well with others ... Link to comment Share on other sites More sharing options...
Dzhon Posted February 3, 2023 Share Posted February 3, 2023 5 hours ago, Frugfath3r said: Привет . Какая система CLEVO вам нужна, возможно, сможет справиться с одной из моих Hello Clevo P870TM-G Link to comment Share on other sites More sharing options...
Frugfath3r Posted February 3, 2023 Share Posted February 3, 2023 Do you have a BIOS programmer ( USB ) ? https://www.ebay.co.uk/itm/174624243499?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=q8lrvxgsqqs&sssrc=2349624&ssuid=yURFKloTQYu&var=&widget_ver=artemis&media=EMAIL If you do then you can go crazy and flash any CLEVO GTX 1080 MXM VBIOS I personally have the dsank VBIOS in SLI for my 870KM then other VBIOS for the DM3 and the 775TM I'm sure I have that VBIOS but will only be back home again on Monday evening. Link to comment Share on other sites More sharing options...
Dzhon Posted February 3, 2023 Share Posted February 3, 2023 1 hour ago, Frugfath3r said: У вас есть программатор BIOS (USB)? https://www.ebay.co.uk/itm/174624243499?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=q8lrvxgsqqs&sssrc=2349624&ssuid=yURFKloTQYu&var=&widget_ver=artemis&media=EMAIL Если да то можно сойти с ума и прошить любую CLEVO GTX 1080 MXM VBIOS Лично у меня стоит dsank VBIOS в SLI для моих 870км затем другой VBIOS для DM3 и 775TM Я уверен, что у меня есть этот VBIOS, но я вернусь домой только в понедельник вечером. The thing is, I can't order this vbios, delivery will take a very long time. I have now installed bios from Alienware... but I really want to find native bios... I can't sli, I have two different cards... one with G sync and this one without G sync Link to comment Share on other sites More sharing options...
Frugfath3r Posted February 3, 2023 Share Posted February 3, 2023 Having one with G-Sync and one without g-sync you will not be able to run this SLI even if you were to flash both with the same VBIOS Both will work in your TM have you tried the dsank version? Link to comment Share on other sites More sharing options...
Dzhon Posted February 3, 2023 Share Posted February 3, 2023 3 minutes ago, Frugfath3r said: Having one with G-Sync and one without g-sync you will not be able to run this SLI even if you were to flash both with the same VBIOS Both will work in your TM have you tried the dsank version? now I don’t want sli, I just want the gpu to work stably, the bios on the laptop from dsank is the latest, I’m looking for vbios for the video card Link to comment Share on other sites More sharing options...
ViktorV Posted February 4, 2023 Share Posted February 4, 2023 14 hours ago, Dzhon said: now I don’t want sli, I just want the gpu to work stably, the bios on the laptop from dsank is the latest, I’m looking for vbios for the video card You seem to have found some kind of bios from MSI and it works Сlevo p870tm1-g 17.3 Fhd 300Hz i9-10980hk ES rtx3060. / Clevo x170smg 17.3 300Hz i9-10850k rtx2070super 32g ddr4 3200Mhz Gskill. / Clevo x170kmg 17.3 2k 165Hz i5-11600k rtx3080 32g ddr4 3200Mhz Hyper-X. Link to comment Share on other sites More sharing options...
runix18 Posted February 4, 2023 Author Share Posted February 4, 2023 On 2/3/2023 at 3:47 PM, ViktorV said: Hello! Why do you need him? I want to help a user from another forum. Desktop - MSI X670E Tomahawk Wifi (cheap Ebay mobo that I fixed) | AMD 7800X3D | 32 GB Trident Z5 Neo RGB 6000Mhz | MSI RTX 4070TI Suprim X | Alienware 27 AW2724DM 2K 165 Hz Gsync | Samsung 990 Pro Nvme - Boot | Other various storage | Windows 10 Pro x64 SOLD - Clevo P870DM-G | i9-9700K 4.5 Ghz on all cores (-50 mv undervolted) | 32GB Hyper X Black 2666MHz | Clevo RTX 2080 3.1b undervolted for better temp 1905Mhz @881 mv | AUO B173HAN03.1 144hz Gsync | Samsung 980 NVME | Dsanke TM BIOS - Chujoi13 adapted based on needs | Network Card: Intel AX210-AX | Windows 10 Pro x64 Link to comment Share on other sites More sharing options...
ViktorV Posted February 6, 2023 Share Posted February 6, 2023 On 2/5/2023 at 3:45 AM, runix18 said: I want to help a user from another forum. bios he found. This is bios gtx1080 OC mxm Clevo 190w tdp. 1080 86.04.80.00.23.rom 1 Сlevo p870tm1-g 17.3 Fhd 300Hz i9-10980hk ES rtx3060. / Clevo x170smg 17.3 300Hz i9-10850k rtx2070super 32g ddr4 3200Mhz Gskill. / Clevo x170kmg 17.3 2k 165Hz i5-11600k rtx3080 32g ddr4 3200Mhz Hyper-X. Link to comment Share on other sites More sharing options...
Scruffy Posted February 28, 2023 Share Posted February 28, 2023 here is some vbios from dsanke bios rar for clevo VBIOS_With_GOP_Updated_To_0x3000A_For_GTX_1000_Series_Graphic_Card.rar 1 Link to comment Share on other sites More sharing options...
runix18 Posted February 28, 2023 Author Share Posted February 28, 2023 2 minutes ago, Scruffy said: here is some vbios from dsanke bios rar for clevo VBIOS_With_GOP_Updated_To_0x3000A_For_GTX_1000_Series_Graphic_Card.rar 1.45 MB · 0 downloads Thank you, but I have all of those. Desktop - MSI X670E Tomahawk Wifi (cheap Ebay mobo that I fixed) | AMD 7800X3D | 32 GB Trident Z5 Neo RGB 6000Mhz | MSI RTX 4070TI Suprim X | Alienware 27 AW2724DM 2K 165 Hz Gsync | Samsung 990 Pro Nvme - Boot | Other various storage | Windows 10 Pro x64 SOLD - Clevo P870DM-G | i9-9700K 4.5 Ghz on all cores (-50 mv undervolted) | 32GB Hyper X Black 2666MHz | Clevo RTX 2080 3.1b undervolted for better temp 1905Mhz @881 mv | AUO B173HAN03.1 144hz Gsync | Samsung 980 NVME | Dsanke TM BIOS - Chujoi13 adapted based on needs | Network Card: Intel AX210-AX | Windows 10 Pro x64 Link to comment Share on other sites More sharing options...
aldarxt Posted February 28, 2023 Share Posted February 28, 2023 I just noticed the pic you posted is almost a duplicate to the card I got by mistake so I'll upload the vbios even tho I have no clue which one it is. If it has gsync or not GP104.rom Clevo P870DM3-G i9-9900k-32.0GB 2667mhz-RTX3080+GTX1080 Alienware M18x R2 i7-3920xm-32GB DDR3-RTX 3000 Alienware M17x R4 i7-3940XM-16GB DDR3-RTX 3000 Alienware M17x R4 i7-3940XM 20GB DDR3-P4000 120hz 3D Precision m6700 i7-3840QM-16GB DDR3-GTX 970M Precision m4700 i7-3840QM-16GB DDR3-T2000M HP ZBook 17 G6 i7 9850H-32GB DDR4-RTX4000maxQ GOBOXX SLM G2721-i7-10875H RTX 3000-32GB ddr4 Link to comment Share on other sites More sharing options...
runix18 Posted February 28, 2023 Author Share Posted February 28, 2023 19 minutes ago, aldarxt said: I just noticed the pic you posted is almost a duplicate to the card I got by mistake so I'll upload the vbios even tho I have no clue which one it is. If it has gsync or not GP104.rom 232.5 kB · 0 downloads It is 10DE 1BA0. 86.04.80.00.23 vbios. non gsync card. Desktop - MSI X670E Tomahawk Wifi (cheap Ebay mobo that I fixed) | AMD 7800X3D | 32 GB Trident Z5 Neo RGB 6000Mhz | MSI RTX 4070TI Suprim X | Alienware 27 AW2724DM 2K 165 Hz Gsync | Samsung 990 Pro Nvme - Boot | Other various storage | Windows 10 Pro x64 SOLD - Clevo P870DM-G | i9-9700K 4.5 Ghz on all cores (-50 mv undervolted) | 32GB Hyper X Black 2666MHz | Clevo RTX 2080 3.1b undervolted for better temp 1905Mhz @881 mv | AUO B173HAN03.1 144hz Gsync | Samsung 980 NVME | Dsanke TM BIOS - Chujoi13 adapted based on needs | Network Card: Intel AX210-AX | Windows 10 Pro x64 Link to comment Share on other sites More sharing options...
aldarxt Posted March 3, 2023 Share Posted March 3, 2023 On 2/28/2023 at 11:02 AM, runix18 said: It is 10DE 1BA0. 86.04.80.00.23 vbios. non gsync card. Riddle Me This, how do I tell the difference from vBios 86.04.80.00.23 and vBios 86.04.80.00.23 ? Clevo P870DM3-G i9-9900k-32.0GB 2667mhz-RTX3080+GTX1080 Alienware M18x R2 i7-3920xm-32GB DDR3-RTX 3000 Alienware M17x R4 i7-3940XM-16GB DDR3-RTX 3000 Alienware M17x R4 i7-3940XM 20GB DDR3-P4000 120hz 3D Precision m6700 i7-3840QM-16GB DDR3-GTX 970M Precision m4700 i7-3840QM-16GB DDR3-T2000M HP ZBook 17 G6 i7 9850H-32GB DDR4-RTX4000maxQ GOBOXX SLM G2721-i7-10875H RTX 3000-32GB ddr4 Link to comment Share on other sites More sharing options...
runix18 Posted March 3, 2023 Author Share Posted March 3, 2023 2 hours ago, aldarxt said: Riddle Me This, how do I tell the difference from vBios 86.04.80.00.23 and vBios 86.04.80.00.23 ? 10DE 1BA0 is non gsync and 10DE 1BE0 is gsync The vbios for gsync cards is 86.04.80.00.24 Desktop - MSI X670E Tomahawk Wifi (cheap Ebay mobo that I fixed) | AMD 7800X3D | 32 GB Trident Z5 Neo RGB 6000Mhz | MSI RTX 4070TI Suprim X | Alienware 27 AW2724DM 2K 165 Hz Gsync | Samsung 990 Pro Nvme - Boot | Other various storage | Windows 10 Pro x64 SOLD - Clevo P870DM-G | i9-9700K 4.5 Ghz on all cores (-50 mv undervolted) | 32GB Hyper X Black 2666MHz | Clevo RTX 2080 3.1b undervolted for better temp 1905Mhz @881 mv | AUO B173HAN03.1 144hz Gsync | Samsung 980 NVME | Dsanke TM BIOS - Chujoi13 adapted based on needs | Network Card: Intel AX210-AX | Windows 10 Pro x64 Link to comment Share on other sites More sharing options...
aldarxt Posted March 3, 2023 Share Posted March 3, 2023 1 hour ago, runix18 said: 10DE 1BA0 is non gsync and 10DE 1BE0 is gsync The vbios for gsync cards is 86.04.80.00.24 So you are looking for vBios 86.04.80.00.23, should be non-gsync, that is in my card. But you want with gsync? I am asking because I ordered another GTX 1080 and now I think there will be a problem as per reading this thread. Its kinda like this is what I should expect when my order comes in Clevo P870DM3-G i9-9900k-32.0GB 2667mhz-RTX3080+GTX1080 Alienware M18x R2 i7-3920xm-32GB DDR3-RTX 3000 Alienware M17x R4 i7-3940XM-16GB DDR3-RTX 3000 Alienware M17x R4 i7-3940XM 20GB DDR3-P4000 120hz 3D Precision m6700 i7-3840QM-16GB DDR3-GTX 970M Precision m4700 i7-3840QM-16GB DDR3-T2000M HP ZBook 17 G6 i7 9850H-32GB DDR4-RTX4000maxQ GOBOXX SLM G2721-i7-10875H RTX 3000-32GB ddr4 Link to comment Share on other sites More sharing options...
aldarxt Posted March 4, 2023 Share Posted March 4, 2023 I'm still poking around in the dark here but this seemed interesting (https://forums.tomshardware.com/threads/can-gpu-vbios-be-flashed-to-support-g-sync.3796049/ ) and this pic just confuses the issue even more. @runix18 the vBios you are looking for is non-gsync Clevo P870DM3-G i9-9900k-32.0GB 2667mhz-RTX3080+GTX1080 Alienware M18x R2 i7-3920xm-32GB DDR3-RTX 3000 Alienware M17x R4 i7-3940XM-16GB DDR3-RTX 3000 Alienware M17x R4 i7-3940XM 20GB DDR3-P4000 120hz 3D Precision m6700 i7-3840QM-16GB DDR3-GTX 970M Precision m4700 i7-3840QM-16GB DDR3-T2000M HP ZBook 17 G6 i7 9850H-32GB DDR4-RTX4000maxQ GOBOXX SLM G2721-i7-10875H RTX 3000-32GB ddr4 Link to comment Share on other sites More sharing options...
runix18 Posted March 4, 2023 Author Share Posted March 4, 2023 25 minutes ago, aldarxt said: I'm still poking around in the dark here but this seemed interesting (https://forums.tomshardware.com/threads/can-gpu-vbios-be-flashed-to-support-g-sync.3796049/ ) and this pic just confuses the issue even more. @runix18 the vBios you are looking for is non-gsync I am not looking anymore, thanks to Viktor. You posted the exact same vbios after him. 1 Desktop - MSI X670E Tomahawk Wifi (cheap Ebay mobo that I fixed) | AMD 7800X3D | 32 GB Trident Z5 Neo RGB 6000Mhz | MSI RTX 4070TI Suprim X | Alienware 27 AW2724DM 2K 165 Hz Gsync | Samsung 990 Pro Nvme - Boot | Other various storage | Windows 10 Pro x64 SOLD - Clevo P870DM-G | i9-9700K 4.5 Ghz on all cores (-50 mv undervolted) | 32GB Hyper X Black 2666MHz | Clevo RTX 2080 3.1b undervolted for better temp 1905Mhz @881 mv | AUO B173HAN03.1 144hz Gsync | Samsung 980 NVME | Dsanke TM BIOS - Chujoi13 adapted based on needs | Network Card: Intel AX210-AX | Windows 10 Pro x64 Link to comment Share on other sites More sharing options...
aldarxt Posted March 13, 2023 Share Posted March 13, 2023 This vBios 86.04.80.00.23 work much better than vBios 86.04.2A.00.2C SLi Compatible, but with DifferentSLIAuto1.7.1-win10_CS, I was able to run SLI with vBios 86.04.80.00.23 GTX 1080 mxm x 2 in P870DM3-G. The only problem, I have to run in "Disable Driver Signature Enforcement" mode cause I don't know how to sign the nvlddmkm.sys for Win 10 to accept it. But I am happy with the performance. 1 Clevo P870DM3-G i9-9900k-32.0GB 2667mhz-RTX3080+GTX1080 Alienware M18x R2 i7-3920xm-32GB DDR3-RTX 3000 Alienware M17x R4 i7-3940XM-16GB DDR3-RTX 3000 Alienware M17x R4 i7-3940XM 20GB DDR3-P4000 120hz 3D Precision m6700 i7-3840QM-16GB DDR3-GTX 970M Precision m4700 i7-3840QM-16GB DDR3-T2000M HP ZBook 17 G6 i7 9850H-32GB DDR4-RTX4000maxQ GOBOXX SLM G2721-i7-10875H RTX 3000-32GB ddr4 Link to comment Share on other sites More sharing options...
