Chitolocz Posted March 6, 2023 Share Posted March 6, 2023 Hello everybody! I have a M15x that was stored for a few years and wanted to use it for my son's first laptop. I've updated the drivers to 531.18 but getting a code 43 on my GPU within device manager and missing info within GPU-Z. Ever come across this issue or know if a fix? Any help would be greatly appreciated! I do have have a custom vbios flash so maybe that is the issue? I used svl7's modified vbios (https://www.techinferno.com/index.php?/files/file/16-nvidia-gtx-970m-oc-edition-rev0zip/) and never had any issues with it. I lost the original vbios after reinstalling windows 🤦♂️ Link to comment Share on other sites More sharing options...
Tenoroon Posted March 6, 2023 Share Posted March 6, 2023 19 minutes ago, Chitolocz said: Hello everybody! I have a M15x that was stored for a few years and wanted to use it for my son's first laptop. I've updated the drivers to 531.18 but getting a code 43 on my GPU within device manager and missing info within GPU-Z. Ever come across this issue or know if a fix? Any help would be greatly appreciated! I do have have a custom vbios flash so maybe that is the issue? I used svl7's modified vbios (https://www.techinferno.com/index.php?/files/file/16-nvidia-gtx-970m-oc-edition-rev0zip/) and never had any issues with it. I lost the original vbios after reinstalling windows 🤦♂️ Try using older drivers. MXM GPUs installed in laptops that were never meant to run said GPU don't act well with newer drivers. If that doesn't work, try flashing a Dell vBIOS to the card, and if that doesn't work, your card is probably on its way out. However, hearing that the card boots normally and still functions without artifacts and crashes shows that it should be a driver or vBIOS problem. Clevo P870TM-G: Core i7 8700k @ 4.8ghz | Clevo RTX 2070 Super | 32gb HyperX DDR4 @ 3200mhz | 17" 1440p 120hz B173QTN01.0 Screen | 256gb Samsung 850 EVO | 500gb WD Blue SSD | Prema BIOS Alienware 17 R1: Core i7 4710mq @ 3.619ghz 741 CBR15 (834 CBR15 @ 4.213ghz) | Dell GTX 860m | 16gb HyperX DDR3L @ 2133mhz | 17" 3D 120hz LTN173HT02-T01 Screen | 256gb mSATA SSD Asus Zephyrus G14: Ryzen 7 4800hs @ 4.2ghz | GTX 1650 | 16gb DDR4 @ 3200mhz | 14" 120hz LM140LF1F01 Screen | 512gb NVME SSD Link to comment Share on other sites More sharing options...
i.bakar Posted March 13, 2023 Share Posted March 13, 2023 i have got that error on my card reader for more then a year and it turned out to be a driver issue. once i updated the driver with the correct one it disappeared.. as for Nvidia drivers , this is my opinion, i don't ever use the latest driver ... i always use the one before the last ... try the 528. Alienware M18X R1, i7 2960XM @ 4.4Ghz, Nvidia GTX 880M SLI , 32GB RAM , samsung 840pro + samsung 860evo ( THE BEST I EVER HAVE) Alienware Area-51M R1, i9 9900K @ 5.1Ghz, Nvidia RTX 2080, 64GB RAM, samsung 980 Pro( LOVELY MACHINE WITH BAD BIOS ) Alienware 18 , I7 4930MX @ 4.2Ghz , GTX 980M SLI, 32GB RAM ( MAY REST IN PEACE) (CAME BACK TO LIFE) Link to comment Share on other sites More sharing options...
