cubusil Posted March 10, 2023 Posted March 10, 2023 Hello guys! I hope someone has a solution for my "problem". I have been using some Alienwares since m15x r1, m18x r1, then m18x r2, m17x r4, and finally the Alienware 17 (120hz, 1070m),so I'm pretty familiar with this brand and it's problems. Right now I've bought an Alienware m17x r4 from eBay (160 euros lol) which was sold as is, and the seller was saying in the description that the laptop just turns on and beeps. I was thinking that it would be a common problem that we all know like dead gpu, or bios corruption. So today the laptop arrived and I've started to check what is wrong with it, and these are the symptoms: when plugged or on battery the laptop turns on for few seconds and then just turns off by itself. No boot logo, no post, nothing. I've pulled the RAM memory to test if the motherboard is "alive" and without RAM memory the board beeps 2 times (so it detects that there is no RAM in it). Swapped the RAM memory for one which is 100% working, and had the same result: turns on for few seconds and turns off. Swapped the CPU, same storie. Tried to turn it on a bios recovery method (hold the "end" button and plug in the charger) the fans are at 100%, laptop stays on for about 20 seconds and also turns off by itself. So if there is anybody who had the same situation as mine and solved it please give an advice. Thank you!
i.bakar Posted March 13, 2023 Posted March 13, 2023 i had the same issue in 2 different laptops alienware 18 and alienware m15 : - the issue in the alienware 18 was the bios is bricked.+ installed an upgraded GPU and didnt change some sittings on the bios ( cant remember what ) what i done is remove all ram and started the laprop , then 2 beebs comming for about 16 times then the laptop restarts ..... after the 16 times repeats and before the laptop turn its self on again there is a 2 second gap in which the laptop is off .... in this 2 seconds window i insert one ram stick ( at any slot ) the the bios reset and the laptop works ... one very important note here ... when u say (the laptop turns on for few seconds and then just turns off by itself) u mean the screen is black or it has a back light shows but now text on the screen ? - the issue with the alienware M15 was the power supply gets hot very quickly and then shuts off ( one good way to test this is try to disasamble the laptop and run it while u can touch the motherboard's power supply ) and see if something gets very hot very fast. however we had to replace the motherboard by a used one. Alienware M18X R1, i7 2960XM @ 4.4Ghz, Nvidia GTX 880M SLI , 32GB RAM , samsung 840pro + samsung 860evo ( THE BEST I EVER HAVE) Alienware Area-51M R1, i9 9900K @ 5.1Ghz, Nvidia RTX 2080, 64GB RAM, samsung 980 Pro( LOVELY MACHINE WITH BAD BIOS ) Alienware M18 R2, i9 14900HX @ 5.2Ghz, Nvidia RTX 4090, 64GB RAM, 4TB SSD (MY current ) Alienware 18 , I7 4930MX @ 4.2Ghz , GTX 980M SLI, 32GB RAM ( MAY REST IN PEACE) (SOLD)
Eban Posted March 13, 2023 Posted March 13, 2023 On 3/11/2023 at 12:00 AM, cubusil said: Hello guys! I hope someone has a solution for my "problem". I have been using some Alienwares since m15x r1, m18x r1, then m18x r2, m17x r4, and finally the Alienware 17 (120hz, 1070m),so I'm pretty familiar with this brand and it's problems. Right now I've bought an Alienware m17x r4 from eBay (160 euros lol) which was sold as is, and the seller was saying in the description that the laptop just turns on and beeps. I was thinking that it would be a common problem that we all know like dead gpu, or bios corruption. So today the laptop arrived and I've started to check what is wrong with it, and these are the symptoms: when plugged or on battery the laptop turns on for few seconds and then just turns off by itself. No boot logo, no post, nothing. I've pulled the RAM memory to test if the motherboard is "alive" and without RAM memory the board beeps 2 times (so it detects that there is no RAM in it). Swapped the RAM memory for one which is 100% working, and had the same result: turns on for few seconds and turns off. Swapped the CPU, same storie. Tried to turn it on a bios recovery method (hold the "end" button and plug in the charger) the fans are at 100%, laptop stays on for about 20 seconds and also turns off by itself. So if there is anybody who had the same situation as mine and solved it please give an advice. Thank you! Oh I remember reading somewhere on the old NBR about a Ranger that did this. Turned out to be the keyboard! Stupid design shuts down pc if kboard wasn't found Hook up a different one if you run out of other ideas 1 Thunderchild // Lenovo Legion Y740 17" i7-9750H rtx2080maxQ win10LTSC RainBird // Alienware 17 (Ranger) i7-4910mq gtx860m win8.1 JunkDog // Desktop Asrock 660M i3-12100F ARC A580 win10LTSC
cubusil Posted March 13, 2023 Author Posted March 13, 2023 3 hours ago, i.bakar said: Hi there again people ! I was aware that I will have to do the "ram stick trick", but was scared a bit, but it seems to be the only solution, I will try to do it and will report to you guys. When I was saying about the screen I meant that it was completely off, it was not showing any activity. 3 hours ago, i.bakar said: - the issue in the alienware 18 was the bios is bricked.+ installed an upgraded GPU and didnt change some sittings on the bios ( cant remember what ) what i done is remove all ram and started the laprop , then 2 beebs comming for about 16 times then the laptop restarts ..... after the 16 times repeats and before the laptop turn its self on again there is a 2 second gap in which the laptop is off .... in this 2 seconds window i insert one ram stick ( at any slot ) the the bios reset and the laptop works ... one very important note here ... when u say (the laptop turns on for few seconds and then just turns off by itself) u mean the screen is black or it has a back light shows but now text on the screen ?
cubusil Posted March 13, 2023 Author Posted March 13, 2023 Hi, thanks for the suggestion I will also verify the keyboard then. 2 hours ago, Eban said: Turned out to be the keyboard! Stupid design shuts down pc if kboard wasn't found Hook up a different one if you run out of other ideas Hi, thanks for the suggestion I will also verify the keyboard then.
i.bakar Posted March 13, 2023 Posted March 13, 2023 15 minutes ago, cubusil said: i'm not trying to let u take it lightly but i did this trick more then 30 times on the same laptop. somestimes 5 or 6 times in one day and even i insert it at the wrong time few times ... nothing ever happened. so don't be scared ( the laptop lights goes off during this 2 seconds ) so if u r worried just keep it repeating a few times until u are confident from managing ur 2 seconds correctly then do it. good luck Alienware M18X R1, i7 2960XM @ 4.4Ghz, Nvidia GTX 880M SLI , 32GB RAM , samsung 840pro + samsung 860evo ( THE BEST I EVER HAVE) Alienware Area-51M R1, i9 9900K @ 5.1Ghz, Nvidia RTX 2080, 64GB RAM, samsung 980 Pro( LOVELY MACHINE WITH BAD BIOS ) Alienware M18 R2, i9 14900HX @ 5.2Ghz, Nvidia RTX 4090, 64GB RAM, 4TB SSD (MY current ) Alienware 18 , I7 4930MX @ 4.2Ghz , GTX 980M SLI, 32GB RAM ( MAY REST IN PEACE) (SOLD)
Eban Posted March 17, 2023 Posted March 17, 2023 @cubusil any progress so far? Thunderchild // Lenovo Legion Y740 17" i7-9750H rtx2080maxQ win10LTSC RainBird // Alienware 17 (Ranger) i7-4910mq gtx860m win8.1 JunkDog // Desktop Asrock 660M i3-12100F ARC A580 win10LTSC
