Hello All,
I need your help. I am trying to replace my GTX 780m by a GTX1070 on my old Clevo P150SM.
My problem is that currently my computer doesn't recognize the card. I am trying to update my Bios but was not successful yet
Any tips / advices ?
Thanks in advance
What card did you get? While not conclusive every instance of the 1070 in the P157SM-A, which I think shares similar platform to the P150SM, was the MSI variant.
Telegram / TS3 / Twitter
Can you take a picture from the card?
I did a p1770sm 1060 upgrade with lvds screen its plug and play, but you have to edit the nvidia driver  in order to install it otherwise its gonna say that no compatible device was found.
In the device manager van you see a second video card next to the intel hd  ?
