Hi, all. Apparently I'm not done tinkering with my m17x.
I'd like to buy a new GPU heatsink for it. I have both the original 3-heatpipe heatsink and an aftermarket 5-heatpipe purchased from... eBay... (can't recall from whom though).
That said, my 5-heatpipe seems like it's a bit off in terms of layout (wherein it doesn't line up very well with the tail-end mosfets) so I'm looking to replace it.
(see this post for a picture of the coverage being... not great)
A recent eBay search brought up these by Cicichen
https://www.ebay.ca/itm/264321972080?hash=item3d8ad13770:g:4T0AAOSw07VafDPA
But I'm not actually sure if the Ranger gpu heatsink will fit in the R4. Anyone try it?
(I imagine I can reach out to Cicichen but I thought I'd ask here first).
AW M18 R1 | i9-13900HX | RTX4090 | 64GB DDR5
AW M17XR4 | i7-3940XM | GTX1070 | 32GB DDR3
AW M15X | i7-940XM | GTX970m | 16GB DDR3
Formerly Schurke of NBR and TechInferno
The Ranger heatsink is slightly different than the M17x R4. One is slightly longer than the other but I can't remember which way it goes. I have tried it and I know that one fits in both but the other doesn't. My gut says that the Ranger one is the one that fits in both because I remember someone posting on NBR that they used Cicichen's Ranger heatsink in their R4.
I have both at home so I can check but I won't be home until Friday morning.
I also once posted images of both heatsinks side by side, either on this forum or on NBR.
Appreciated! I could have sworn they were _mostly_ interchangeable (like, when i ordered my 5-pipe I seem to recall it was for either) but the purchase is far enough back that I don't have any records for it (which seems crazy but there you have it).
I uh... plumbed the nbr archive for a hot second... It's pretty wild in there!
All right--
So the currently available 5-pipe ranger heatsink from Cicichen won't fit in the m17xR4; the pipes and fins are longer and exceed the amount of available space in the chassis.
I've mounted up a p5000 on their current 3-pipe m17xr4 heatsink. That does fit.
I'm not sure what to do with the exposed memory on the back of the card though. I suppose I could sandwich in some silicone padding to abut them to the motherboard and do _something_. IIRC the 680m was mounted that way. Any thoughts there?
That said, I'm getting some interesting numbers off the p5000. First, idle temperature is higher (like 47c)... I suspected a bad mount until I ran a furmark test.
Furmark load test:
Temp: ~64c --> low but tracks with what appears to be a lower-wattage card
Board draw: ~100w
Chip draw: ~50w
Core clock: ~1570mhz
Memory clock 1500mhz --> very interesting there. IIRC 1070 cards usually run at 2000mhz
Firestrike: Graphics at 16000, which is some-ways off from the 17000-18000 on the 1070s I've had
Also, overclocking appears to be locked-out.
(Anyway - I'll start a new topic because this is getting into p5000 performance and operations)
  • 2 months later...
