Naberius Posted December 4, 2023 Posted December 4, 2023 All right... here's a weird one; In trying to track down a non-specific, dismiss-able error code, I replaced the CMOS battery in my laptop. Funny thing is, the laptop won't accept the replacement battery... I've now tried a handful of different CR2032 batteries of different makes (Duracell, Panasonic) and I'm getting 5 beep error codes off all of them. The original battery is a KTS Japan CR2032 and the laptop will start fine on it (albeit with the odd error beep I can dismiss still). (Odd additional detail: testing the original battery with an analog tester: it reads at the bottom of acceptable charge. The new ones read "full" then slowly tick down to low... This is the case for both the Panasonic and Duracell batteries I've tested) Anyone encountered a case where their laptop won't accept... what should be valid replacement batteries? AW M18 R1 | i9-13900HX | RTX4090 | 64GB DDR5 AW M17XR4 | i7-3940XM | GTX1070 | 32GB DDR3 AW M15X | i7-940XM | GTX970m | 16GB DDR3 Formerly Schurke of NBR and TechInferno
Jerryzago Posted December 4, 2023 Posted December 4, 2023 Maybe its a long shot. Try a complete power drain. Put the old battery back. Also the main battery. Connect charger. Power on system. Shut down from OS. Remove main battery. Press power for 30sec. Remove Cmos battery. Press again for 30sec. Place new Cmos battery. Place main battery. Connect charger. Power on and enter bios. Set proper values and power down to check again if settings remain there. If you have any beep, press incert key when you press power button (used work on some old bios). Hope this help you. Alienware M18x R2 / i7 3720qm -> i7 3940XM / Dual 7970m -> 980m SLI -> HP Quadro RTX 3000 Alienware 17 R1 / 4710MQ -> 4930mx / 880M GTX -> PNY Quadro RTX 3000 HP 8570w / i7 3820qm / Quadro K2000M HP DV6500 / i7 T7200 -> i7 T9500 / 2GB RAM -> 4GB RAM / Atlas OS
Maxware79 Posted December 5, 2023 Posted December 5, 2023 If the power drain doesn't work then your issue is probably on the motherboard and it possibly isn't fixable, unless you are good at locating board level repairs. Alienware Aurora R15 - i9-13900KF - RTX 4090 - 32GB DDR5 Alienware X51 - i7-3770 - GTX 1060 - 16GB 1600Mhz DDR3 Alienware M17x R3 - i7-2760QM - GTX 580M - 16GB 1600Mhz DDR3 Alienware Area 51 ALX - i7-975 Extreme - GTX 980 - 16GB 1600Mhz DDR3 Alienware Aurora R2 - i7-3770K - GTX 670FTW - 16GB 1600Mhz DDR3 Alienware Aurora R4 ALX - i7-3930K - GTX 1060 - 16GB 1600Mhz DDR3 Alienware Aurora R4 ALX - i7-3930K - GTX 670FTW - 16GB 1600Mhz DDR3
Naberius Posted December 11, 2023 Author Posted December 11, 2023 This is intensely stupid (perhaps on my part): I was able to get the board to accept a new battery by... firing it up with the new battery, getting the 5 beep rejection, powering down, then (on a lark) powering back up again... Accepted; Just using a regular Duracell CR2032. 1 AW M18 R1 | i9-13900HX | RTX4090 | 64GB DDR5 AW M17XR4 | i7-3940XM | GTX1070 | 32GB DDR3 AW M15X | i7-940XM | GTX970m | 16GB DDR3 Formerly Schurke of NBR and TechInferno
ShadowMirror Posted January 1, 2025 Posted January 1, 2025 (edited) On 12/5/2023 at 2:00 PM, Maxware79 said: …unless you are good at locating board level repairs. Any guides on how to do this out there? I don’t want to lose my M17x R3 to an easy fix that is just foreign to me. Edited January 1, 2025 by ShadowMirror Clarification
