Csupati Posted December 20, 2023 Posted December 20, 2023 Hi. Guys, somebody know what is the max power draw on the P751 that a 9900k can make, at what wattage and voltage? Lets say it has the AliExpress water cooler. Clevo P751TM1-G 8700K/16GB/GTX 1080@120W/1.5TB/FHD 144 G-Sync/ Asus PG279Q
Meaker Posted December 22, 2023 Posted December 22, 2023 If it's like the 870TM then a fair amount but there are several power limits you have to raise. 1 Louqe Ghost S1 case (Top hat and bottom extension) Powercolor RX 9070 XT Reaper 16GB 32" MSI 4k 160HZ IPS display AMD Ryzen 7 7700 cooled via Thermalright 240mm AIO 48GB (2x24) DDR5 6000 CL36 Asus B650E-I motherboard 2TB T500 nvme SSD + 2TB SN770 nvme Corsair SF750 platinum SFX PSU
Csupati Posted January 2, 2024 Author Posted January 2, 2024 On 12/22/2023 at 6:11 PM, Meaker said: If it's like the 870TM then a fair amount but there are several power limits you have to raise. So it can handle like a desktop mobo, 200-250W only cpu? Clevo P751TM1-G 8700K/16GB/GTX 1080@120W/1.5TB/FHD 144 G-Sync/ Asus PG279Q
Meaker Posted January 3, 2024 Posted January 3, 2024 In my machine the 9900KS I do run mine heavily undervolted at 4.8Ghz to give the system a reasonable chance. Louqe Ghost S1 case (Top hat and bottom extension) Powercolor RX 9070 XT Reaper 16GB 32" MSI 4k 160HZ IPS display AMD Ryzen 7 7700 cooled via Thermalright 240mm AIO 48GB (2x24) DDR5 6000 CL36 Asus B650E-I motherboard 2TB T500 nvme SSD + 2TB SN770 nvme Corsair SF750 platinum SFX PSU
1610ftw Posted January 7, 2024 Posted January 7, 2024 On 1/2/2024 at 11:00 AM, Csupati said: So it can handle like a desktop mobo, 200-250W only cpu? Â I doubt that you will be able to sustain much more than 150 to 160W on a semi-constant basis and with a special heatsink. Maybe up tp 200W with a single run of cinebench but not for very long.
anassa Posted January 12, 2024 Posted January 12, 2024 On 12/20/2023 at 3:42 PM, Csupati said: Hi. Guys, somebody know what is the max power draw on the P751 that a 9900k can make, at what wattage and voltage? Lets say it has the AliExpress water cooler.  I am working on my P750 so basically the same and I have the AliExpress cooler, but the air cooler. I have difficulty keeping 90w cool with a custom fan curve, fans full blast would probably be fine though. But I think I can do better, but I am shooting for being able to cool ~100w consistently so something like 200w would be too much I think. I currently have a 8700k in it, but have a 9900k I will try eventually too. But - on the GPU side it does a really good job keeping it cool, I just need to dial in the CPU side contact. Previous lives: D900F / P150HM / P150EM / P870DM2 / X170KM Testing/Backup Rig - P750DM2 - **in process** - *Build Thread* Wife's Daily - P750DM2- 4k Panel / 6700k / 1060 GTX / 64GB DDR4 3200Mhz Corsair Vengeance / 1TB Samsung 970 Plus / 2TB WD Black SN770 / Killer Wifi Self Daily - P750DM2 (2016) - Dsanke BIOS / 8700k (2017) / 2080 RTX (2019) / 64GB DDR4 3200Mhz CL16 Ballistix / ETC Determined to keep the socketed 15.6" laptops alive as long as possible!!
