Naberius Posted December 29, 2023 Share Posted December 29, 2023 Hi, all My m15x has a new career as a (jenkins agent) build box and (min spec) testing rig. That said, I'd like to re-GPU it because the ancient firepro isn't bringing much to the table. I have a (unmolested) 970m on hand but I seem to recall the m15x not being great at powering it (like, back to pinmod and messing with toggling stealth mode territory). At one point I had a 970m with an undervolted vbios in there (maybe SL7s work?) but it was still a "mess with it every time you're about to do something graphically intensive", which I'd like to avoid for this. Were there other, less flaky/troublesome, options? I noticed m3000ms on ebay for... not much. Anyone mess with those? AW M18 R1 | i9-13900HX | RTX4090 | 64GB DDR5 AW M17XR4 | i7-3940XM | GTX1070 | 32GB DDR3 AW M15X | i7-940XM | GTX970m | 16GB DDR3 Formerly Schurke of NBR and TechInferno Link to comment Share on other sites More sharing options...
ssj92 Posted February 4, 2024 Share Posted February 4, 2024 I'd run the 970M. I am currently running a 980M and while I can't use it to its full potential, it runs faster than anything else I can throw in here. 970M should work better since it uses less power. You can try undervolting it 1 Alienware Area-51 18 : Intel Core Ultra 9 275HX @ ??? | nVidia GeForce RTX 5090 | BE200 | 1TB Gen5 9100 PRO Alienware Area-51M : Intel Core i9-9900K @ 5.3Ghz | nVidia GeForce RTX 2080 | AX210 | Samsung 970 Evo+ Alienware M18x R2 : Intel Core i7 3920XM @ 4.7Ghz | nVidia GeForce RTX 3080 | AX210 | Samsung 980 PRO Alienware 18 : Intel Core i7 4930MX @ 4.5Ghz | nVidia Quadro RTX 5000 | AX210 | Samsung 980 NVMe More Laps: M14x | M14xR2 | M15x (980m) | M17xR2 (RTX 3000) | M17xR3 (WX 7100) | M18xR1 (RTX 5000) BEAST Server: Intel Xeon W7-3465X 28 P-Cores | 2x nVidia RTX Titan | 128GB RDIMM | Intel Optane P5800X CS Studios YouTube: https://www.youtube.com/c/CSStudiosYT Link to comment Share on other sites More sharing options...
2CPU Posted August 30 Share Posted August 30 The 980M can run Occulus rift if you get the special modded USB drivers. Not sure if they are around anymore as notebook forum went down but it was legit. Link to comment Share on other sites More sharing options...
