umm....sure sure bud whatever makes u happy 😄
10 hours ago, Snowleopard said:
The 10900KF should be fine with 4k displays?
9 hours ago, Etern4l said:
Dicey, depending on the software/title. Roughly 1/3 of the 13900K performance. I keep hearing current CPUs aren't enough to feed the 4090 (desktop).
thats correct with the 4090, but only up to 1440p. at 4K all the higher-end CPUs are pretty much equal, i.e. in full GPU bottleneck. but also true, not sure how the 10900K would fare here...
i was skeptical when u said 1/3, but it turns out its like 2.3-2.4x (14900K vs. 10900K), crazy stuff!
Would any of these work and are any of them newer than the rtx3080? I assume game support is limited for quattro cards.
https://www.advantech.com/en/products/nvidia-mxm-gpu-cards/sub_08465970-d3a1-44e2-8aa8-7e84eb1cd608
game support isnt the issue here, driver wise youd be set. problem would rather be to get it running in the first place. both cooling wise (heatsink compatibility for the layout), as well as vBios / sBios, make it boot up and display output.
