carlc1okc Posted February 22, 2024 Posted February 22, 2024 Have been trying to get my m4800 laptop to connect to my Dell monitor for months. I have a m4700 which works fine but when I purchased the Dell monitor it will not work with the m4800. Have talked to Dell and they thought it was the monitor and sent a replacement. Replacement did not work either. Any help would be appreciated.
Aaron44126 Posted February 22, 2024 Posted February 22, 2024 Does it work with any monitor (using the same port)? Apple MacBook Pro 16-inch, 2023 (personal) • Dell Precision 7560 (work) • Full specs in spoiler block below Info posts (Windows) — Turbo boost toggle • The problem with Windows 11 • About Windows 10/11 LTSC Spoiler Apple MacBook Pro 16-inch, 2023 (personal) M2 Max 4 efficiency cores 8 performance cores 38-core Apple GPU 96GB LPDDR5-6400 8TB SSD macOS 15 "Sequoia" 16.2" 3456×2234 120 Hz mini-LED ProMotion display Wi-Fi 6E + Bluetooth 5.3 99.6Wh battery 1080p webcam Fingerprint reader Also — iPhone 12 Pro 512GB, Apple Watch Series 8 Dell Precision 7560 (work) Intel Xeon W-11955M ("Tiger Lake") 8×2.6 GHz base, 5.0 GHz turbo, hyperthreading ("Willow Cove") 64GB DDR4-3200 ECC NVIDIA RTX A2000 4GB Storage: 512GB system drive (Micron 2300) 4TB additional storage (Sabrent Rocket Q4) Windows 11 Enterprise LTSC 2024 15.6" 3940×2160 IPS display Intel Wi-Fi AX210 (Wi-Fi 6E + Bluetooth 5.3) 95Wh battery 720p IR webcam Fingerprint reader Previous Dell Precision 7770, 7530, 7510, M4800, M6700 Dell Latitude E6520 Dell Inspiron 1720, 5150 Dell Latitude CPi
carlc1okc Posted February 23, 2024 Author Posted February 23, 2024 Hi, I did have another monitor but I gave it away to my grandson, I didn't think I would have a problem with the new Dell monitor. Like I said I can use the monitor with my M4700 with no problem. Thanks for your reply, Carl
