ryan Posted April 2, 2024 Posted April 2, 2024 (edited) Hi guys. I have Be200--works ax210--not working mt7922--not working s21 ultra cell phone---works as you can see my 6e router spits out 6ghz at 1700mbps my zenbook wont connect or show 6ghz bands with its mt7922 wifi card my hp omen with its ax210 also wont show or connect to 6ghz bands what region setting are required and what do I do to get this working, I seem to be the only one on the planet un able to get 6 ghz working with 6e cards. the wifi 7 card was plug and play and worked out of the box Edited April 2, 2024 by Reciever Do not incentivize via monetary or otherwise for resolution. Thanks ZEUS-COMING SOON Omen 16 2021
ryan Posted May 1, 2024 Author Posted May 1, 2024 bought a BE200 and it installed flawlessly. wifi 7 is the way to go. default settings it saw the 6ghz band/ one happy camper ZEUS-COMING SOON Omen 16 2021
TreeTopsRanch Posted May 3, 2024 Posted May 3, 2024 About $40 on Amazon. That seems to be a good price. Wish I could put one of those in my Del G7-17 7790 laptop.
ryan Posted May 5, 2024 Author Posted May 5, 2024 yeah I have a few laptops that cant use it like my chromebook and zenbook amd. pity amd doesnt support it as the zenbook is my favorite laptop in my collection. just ordered a wifi 7 router with my disability money was 350 but should be able to combine my two internets for a total of 2.6gbps and of that 2.6gbs ill accept 2.5gbps lol. crazy fast internet in a few hours. very excited. ill likely have the fastest internet setup in my city. ZEUS-COMING SOON Omen 16 2021
