papjco32 Posted May 8, 2024 Share Posted May 8, 2024 Hi all. I recently got my hands on a p775-dm3 and i tried to use this: to flash the dsanke bios for my machine. I used the p7xx-dmx 0729 file from here: https://github.com/supermarsx/other-clevo-modded-bios now the laptop refuses to post. I have a ch341a programmer and using the CH341A_CH347 Programmer V2.0 program i was able to flash the backup i made before it went down, but no dice. Also tried flashing the 511 ver of dsanke and no dice. Tried the bios from clevos website, no dice. Let me know what I'm missing here, i honestly just wanna flash the stock bios back rather than dsanke, trying to install the dsanke bios bricked it so i don't know. Any help is appreciated. Thanks, Jon Link to comment Share on other sites More sharing options...
papjco32 Posted May 8, 2024 Author Share Posted May 8, 2024 update: flashed the wrong chip. i was flashing an 8mbit chip over by the usb, hopefully its ok. found the bios chip backed it up, and then flashed the backup from earlier to no avail. also tried the one from clevos website, no dice. when i flashed either one i got this error: Verification error on address: 0x00000032, Device: 0x8C, Buffer: 0xCC Â i also switched to neoprogrammer to see if it would make a difference. it didn't. i will continue to use it it provides a lot more info. Link to comment Share on other sites More sharing options...
runix18 Posted May 9, 2024 Share Posted May 9, 2024 18 hours ago, papjco32 said: update: flashed the wrong chip. i was flashing an 8mbit chip over by the usb, hopefully its ok. found the bios chip backed it up, and then flashed the backup from earlier to no avail. also tried the one from clevos website, no dice. when i flashed either one i got this error: Verification error on address: 0x00000032, Device: 0x8C, Buffer: 0xCC  i also switched to neoprogrammer to see if it would make a difference. it didn't. i will continue to use it it provides a lot more info.  You need to flash this with programmer.    Desktop - MSI X670E Tomahawk Wifi (cheap Ebay mobo that I fixed) | AMD 9800X3D | 64GB Corsair Vengeance RGB DDR5 6000MHz CL30 Dual Channel Kit | MSI RTX 4070TI Suprim X  | Alienware 27 AW2724DM 2K 165 Hz Gsync | Samsung 990 Pro Nvme - Boot | Other various storage | Windows 11 Enterprise x64 SOLD - Clevo P870DM-G | i9-9700K 4.5 Ghz on all cores (-50 mv undervolted) | 32GB Hyper X Black 2666MHz | Clevo RTX 2080 3.1b undervolted for better temp 1905Mhz @881 mv | AUO B173HAN03.1 144hz Gsync | Samsung 980 NVME | Dsanke TM BIOS - Chujoi13 adapted based on needs | Network Card: Intel AX210-AX | Windows 10 Pro x64  Link to comment Share on other sites More sharing options...
papjco32 Posted May 10, 2024 Author Share Posted May 10, 2024 8 hours ago, runix18 said:  You need to flash this with programmer.    i did using the backup i had and the official bios from clevo. I'm pretty sure i need the contents of this chip (see attached pic, in blue) as it is the chip i flashed and (like a dum dum) didn't take a backup of. a source of that would be great. on a different note, what do i need for the machine to start properly? I've been testing with cpu gpu mobo heatsink ram power button and sdd, do you need more than that? Thanks for any advice, buying a $250 mobo from aliexpress does not sound great to me lol Link to comment Share on other sites More sharing options...
runix18 Posted May 10, 2024 Share Posted May 10, 2024 14 hours ago, papjco32 said: i did using the backup i had and the official bios from clevo. I'm pretty sure i need the contents of this chip (see attached pic, in blue) as it is the chip i flashed and (like a dum dum) didn't take a backup of. a source of that would be great. on a different note, what do i need for the machine to start properly? I've been testing with cpu gpu mobo heatsink ram power button and sdd, do you need more than that? Thanks for any advice, buying a $250 mobo from aliexpress does not sound great to me lol You need to find someone who has a P775DM3 and is willing to make a backup image from that chip for you. Try asking in the P775 subforum. Desktop - MSI X670E Tomahawk Wifi (cheap Ebay mobo that I fixed) | AMD 9800X3D | 64GB Corsair Vengeance RGB DDR5 6000MHz CL30 Dual Channel Kit | MSI RTX 4070TI Suprim X  | Alienware 27 AW2724DM 2K 165 Hz Gsync | Samsung 990 Pro Nvme - Boot | Other various storage | Windows 11 Enterprise x64 SOLD - Clevo P870DM-G | i9-9700K 4.5 Ghz on all cores (-50 mv undervolted) | 32GB Hyper X Black 2666MHz | Clevo RTX 2080 3.1b undervolted for better temp 1905Mhz @881 mv | AUO B173HAN03.1 144hz Gsync | Samsung 980 NVME | Dsanke TM BIOS - Chujoi13 adapted based on needs | Network Card: Intel AX210-AX | Windows 10 Pro x64  Link to comment Share on other sites More sharing options...
papjco32 Posted May 24, 2024 Author Share Posted May 24, 2024 So I bought a replacement motherboard from ali-express, hoping all I have to do is copy the chip to get old one working again. If not I will just replace the motherboard. With that being said, i have a qtj1 (10th gen es) CPU that I wanna use, so where do I get the intel me disabled dsanke bios @runix18? (As far as I know this is the one I need) Also, do I need to cover any pins for that CPU? Reading different forum posts here it seems like you don't need too. Thanks in advance for all the help. Link to comment Share on other sites More sharing options...
runix18 Posted May 24, 2024 Share Posted May 24, 2024 43 minutes ago, papjco32 said: So I bought a replacement motherboard from ali-express, hoping all I have to do is copy the chip to get old one working again. If not I will just replace the motherboard. With that being said, i have a qtj1 (10th gen es) CPU that I wanna use, so where do I get the intel me disabled dsanke bios @runix18? (As far as I know this is the one I need) Also, do I need to cover any pins for that CPU? Reading different forum posts here it seems like you don't need too. Thanks in advance for all the help. Here is the bios. As for the mutant CPU you do not need to isolate any pins. P7xxDM3_ME_Disabled.zip Desktop - MSI X670E Tomahawk Wifi (cheap Ebay mobo that I fixed) | AMD 9800X3D | 64GB Corsair Vengeance RGB DDR5 6000MHz CL30 Dual Channel Kit | MSI RTX 4070TI Suprim X  | Alienware 27 AW2724DM 2K 165 Hz Gsync | Samsung 990 Pro Nvme - Boot | Other various storage | Windows 11 Enterprise x64 SOLD - Clevo P870DM-G | i9-9700K 4.5 Ghz on all cores (-50 mv undervolted) | 32GB Hyper X Black 2666MHz | Clevo RTX 2080 3.1b undervolted for better temp 1905Mhz @881 mv | AUO B173HAN03.1 144hz Gsync | Samsung 980 NVME | Dsanke TM BIOS - Chujoi13 adapted based on needs | Network Card: Intel AX210-AX | Windows 10 Pro x64  Link to comment Share on other sites More sharing options...
papjco32 Posted June 1, 2024 Author Share Posted June 1, 2024 On 5/24/2024 at 9:34 AM, runix18 said: Here is the bios. As for the mutant CPU you do not need to isolate any pins. P7xxDM3_ME_Disabled.zip 3.68 MB · 1 download So I got the laptop to POST (yay) flashed the bios (it now says clevo flashed by dsanke or something like that for the boot logo), tried to put in the qtj1 cpu and it wouldn't fit. so i delided it and that made it fit but it wont post. i tried with just one stick of 8gb 2133mhz sk hyniks (this same stick works w my 7th gen i7) to make it wasn't ram and it still didn't post. is this something i need to ask @ViktorV about? also i bought a b173han05.2 display and i guess i got the wrong cable, i bought https://www.aliexpress.us/item/2251832620880374.html?spm=a2g0o.order_list.order_list_main.29.51be1802Xm5ZCE&gatewayAdapt=glo2usa (P775 40P 0.5mm 46cm) I'm guessing i needed "P775 40P 0.4mm 46cm" instead as the one i have is too big of connector. (is this a good price? if not can you link me?) Thanks in advance 🙂 Link to comment Share on other sites More sharing options...
papjco32 Posted June 1, 2024 Author Share Posted June 1, 2024 is the me fw version supposed to have a number? if so it does. also the flash deff worked cause there is a lot more in the bios lol is there a dsanke bios manual? if so i need it XD IMG_0077[1].HEIC Link to comment Share on other sites More sharing options...
runix18 Posted June 1, 2024 Share Posted June 1, 2024 No me fw version on me fw disabled version Desktop - MSI X670E Tomahawk Wifi (cheap Ebay mobo that I fixed) | AMD 9800X3D | 64GB Corsair Vengeance RGB DDR5 6000MHz CL30 Dual Channel Kit | MSI RTX 4070TI Suprim X  | Alienware 27 AW2724DM 2K 165 Hz Gsync | Samsung 990 Pro Nvme - Boot | Other various storage | Windows 11 Enterprise x64 SOLD - Clevo P870DM-G | i9-9700K 4.5 Ghz on all cores (-50 mv undervolted) | 32GB Hyper X Black 2666MHz | Clevo RTX 2080 3.1b undervolted for better temp 1905Mhz @881 mv | AUO B173HAN03.1 144hz Gsync | Samsung 980 NVME | Dsanke TM BIOS - Chujoi13 adapted based on needs | Network Card: Intel AX210-AX | Windows 10 Pro x64  Link to comment Share on other sites More sharing options...
papjco32 Posted June 2, 2024 Author Share Posted June 2, 2024 5 hours ago, runix18 said: No me fw version on me fw disabled version well i flash that zip linked above and it says "ME FW Version: 61665.9.41688.14353" in the bios i thought i linked to that picture, my bad right one is below IMG_0076[1].HEIC Link to comment Share on other sites More sharing options...
runix18 Posted June 2, 2024 Share Posted June 2, 2024 ME FW Version: 61665.9.41688.14353 - that number is an error number shown by bios because of me disabled modules (meaning no such me number exists). Desktop - MSI X670E Tomahawk Wifi (cheap Ebay mobo that I fixed) | AMD 9800X3D | 64GB Corsair Vengeance RGB DDR5 6000MHz CL30 Dual Channel Kit | MSI RTX 4070TI Suprim X  | Alienware 27 AW2724DM 2K 165 Hz Gsync | Samsung 990 Pro Nvme - Boot | Other various storage | Windows 11 Enterprise x64 SOLD - Clevo P870DM-G | i9-9700K 4.5 Ghz on all cores (-50 mv undervolted) | 32GB Hyper X Black 2666MHz | Clevo RTX 2080 3.1b undervolted for better temp 1905Mhz @881 mv | AUO B173HAN03.1 144hz Gsync | Samsung 980 NVME | Dsanke TM BIOS - Chujoi13 adapted based on needs | Network Card: Intel AX210-AX | Windows 10 Pro x64  Link to comment Share on other sites More sharing options...
papjco32 Posted June 2, 2024 Author Share Posted June 2, 2024 4 minutes ago, runix18 said: ME FW Version: 61665.9.41688.14353 - that number is an error number shown by bios because of me disabled modules (meaning no such me number exists). do you have any idea why it wouldn't post the qtj1 cpu then? Link to comment Share on other sites More sharing options...
runix18 Posted June 2, 2024 Share Posted June 2, 2024 Does it work with a regular cpu? does it post? Desktop - MSI X670E Tomahawk Wifi (cheap Ebay mobo that I fixed) | AMD 9800X3D | 64GB Corsair Vengeance RGB DDR5 6000MHz CL30 Dual Channel Kit | MSI RTX 4070TI Suprim X  | Alienware 27 AW2724DM 2K 165 Hz Gsync | Samsung 990 Pro Nvme - Boot | Other various storage | Windows 11 Enterprise x64 SOLD - Clevo P870DM-G | i9-9700K 4.5 Ghz on all cores (-50 mv undervolted) | 32GB Hyper X Black 2666MHz | Clevo RTX 2080 3.1b undervolted for better temp 1905Mhz @881 mv | AUO B173HAN03.1 144hz Gsync | Samsung 980 NVME | Dsanke TM BIOS - Chujoi13 adapted based on needs | Network Card: Intel AX210-AX | Windows 10 Pro x64  Link to comment Share on other sites More sharing options...
papjco32 Posted June 2, 2024 Author Share Posted June 2, 2024 1 hour ago, runix18 said: Does it work with a regular cpu? does it post? yup my 7700k works 100 percent its got one 8gb stick of sk hynix 2133mhz to make sure the ram works Link to comment Share on other sites More sharing options...
runix18 Posted June 3, 2024 Share Posted June 3, 2024 10 hours ago, papjco32 said: yup my 7700k works 100 percent its got one 8gb stick of sk hynix 2133mhz to make sure the ram works I dunno then. Bios wise it have been made by dsanke specialy for this mutant CPU. If everything is rulled out the only thing remaining is the CPU itself. Desktop - MSI X670E Tomahawk Wifi (cheap Ebay mobo that I fixed) | AMD 9800X3D | 64GB Corsair Vengeance RGB DDR5 6000MHz CL30 Dual Channel Kit | MSI RTX 4070TI Suprim X  | Alienware 27 AW2724DM 2K 165 Hz Gsync | Samsung 990 Pro Nvme - Boot | Other various storage | Windows 11 Enterprise x64 SOLD - Clevo P870DM-G | i9-9700K 4.5 Ghz on all cores (-50 mv undervolted) | 32GB Hyper X Black 2666MHz | Clevo RTX 2080 3.1b undervolted for better temp 1905Mhz @881 mv | AUO B173HAN03.1 144hz Gsync | Samsung 980 NVME | Dsanke TM BIOS - Chujoi13 adapted based on needs | Network Card: Intel AX210-AX | Windows 10 Pro x64  Link to comment Share on other sites More sharing options...
TheWizzard1 Posted June 13, 2024 Share Posted June 13, 2024 One strange thing I saw a while back working through some of these with BIOS mods - Occasionally after flash / CPU swap / GPU swap, the unit absolutely refused to POST. Pressing and holding FN + D on the keyboard for a solid minute immediately after pressing the power button has helped many times! Link to comment Share on other sites More sharing options...
papjco32 Posted June 15, 2024 Author Share Posted June 15, 2024 hey all i recently replaced my screen with B173HAN05.2 and no longer get display in the bios. it works 100 percent in windows 11, but in recovery or bios its just a black screen. any ideas? thanks in advance. Link to comment Share on other sites More sharing options...
runix18 Posted June 15, 2024 Share Posted June 15, 2024 7 minutes ago, papjco32 said: hey all i recently replaced my screen with B173HAN05.2 and no longer get display in the bios. it works 100 percent in windows 11, but in recovery or bios its just a black screen. any ideas? thanks in advance. Maybe a GOP update will help?  Desktop - MSI X670E Tomahawk Wifi (cheap Ebay mobo that I fixed) | AMD 9800X3D | 64GB Corsair Vengeance RGB DDR5 6000MHz CL30 Dual Channel Kit | MSI RTX 4070TI Suprim X  | Alienware 27 AW2724DM 2K 165 Hz Gsync | Samsung 990 Pro Nvme - Boot | Other various storage | Windows 11 Enterprise x64 SOLD - Clevo P870DM-G | i9-9700K 4.5 Ghz on all cores (-50 mv undervolted) | 32GB Hyper X Black 2666MHz | Clevo RTX 2080 3.1b undervolted for better temp 1905Mhz @881 mv | AUO B173HAN03.1 144hz Gsync | Samsung 980 NVME | Dsanke TM BIOS - Chujoi13 adapted based on needs | Network Card: Intel AX210-AX | Windows 10 Pro x64  Link to comment Share on other sites More sharing options...
papjco32 Posted June 15, 2024 Author Share Posted June 15, 2024 4 hours ago, runix18 said: Maybe a GOP update will help? Â what is GOP update? and do you have links on how to do it? Link to comment Share on other sites More sharing options...
runix18 Posted June 15, 2024 Share Posted June 15, 2024 What GPU do you have?  Desktop - MSI X670E Tomahawk Wifi (cheap Ebay mobo that I fixed) | AMD 9800X3D | 64GB Corsair Vengeance RGB DDR5 6000MHz CL30 Dual Channel Kit | MSI RTX 4070TI Suprim X  | Alienware 27 AW2724DM 2K 165 Hz Gsync | Samsung 990 Pro Nvme - Boot | Other various storage | Windows 11 Enterprise x64 SOLD - Clevo P870DM-G | i9-9700K 4.5 Ghz on all cores (-50 mv undervolted) | 32GB Hyper X Black 2666MHz | Clevo RTX 2080 3.1b undervolted for better temp 1905Mhz @881 mv | AUO B173HAN03.1 144hz Gsync | Samsung 980 NVME | Dsanke TM BIOS - Chujoi13 adapted based on needs | Network Card: Intel AX210-AX | Windows 10 Pro x64  Link to comment Share on other sites More sharing options...
papjco32 Posted June 15, 2024 Author Share Posted June 15, 2024 4 minutes ago, runix18 said: What GPU do you have? Â 1080, i used this file i found on the fourm and it seems to work, i can now see the splash screen VBIOS_With_GOP_Updated_To_0x3000A_For_GTX_1000_Series_Graphic_Card.rar Link to comment Share on other sites More sharing options...
runix18 Posted June 15, 2024 Share Posted June 15, 2024 1 hour ago, papjco32 said: 1080, i used this file i found on the fourm and it seems to work, i can now see the splash screen VBIOS_With_GOP_Updated_To_0x3000A_For_GTX_1000_Series_Graphic_Card.rar 1.45 MB · 0 downloads Good job, you just needed a point in the right direction. Desktop - MSI X670E Tomahawk Wifi (cheap Ebay mobo that I fixed) | AMD 9800X3D | 64GB Corsair Vengeance RGB DDR5 6000MHz CL30 Dual Channel Kit | MSI RTX 4070TI Suprim X  | Alienware 27 AW2724DM 2K 165 Hz Gsync | Samsung 990 Pro Nvme - Boot | Other various storage | Windows 11 Enterprise x64 SOLD - Clevo P870DM-G | i9-9700K 4.5 Ghz on all cores (-50 mv undervolted) | 32GB Hyper X Black 2666MHz | Clevo RTX 2080 3.1b undervolted for better temp 1905Mhz @881 mv | AUO B173HAN03.1 144hz Gsync | Samsung 980 NVME | Dsanke TM BIOS - Chujoi13 adapted based on needs | Network Card: Intel AX210-AX | Windows 10 Pro x64  Link to comment Share on other sites More sharing options...
papjco32 Posted June 16, 2024 Author Share Posted June 16, 2024 On 6/15/2024 at 2:06 PM, runix18 said: Good job, you just needed a point in the right direction. thanks 4 the help Link to comment Share on other sites More sharing options...
taiyang Posted August 15, 2024 Share Posted August 15, 2024 Well. That 0729 BIOS from Dsanke was migrated from TM machine with Z370. To flash it using fpt in OS on a DM machine with Z170, you need to  1. flash without your battery using only the power cord, and 2. unplug the power cord after the flashing. DO NOT restart with power. 3. connect the battery and power cord back and boot the machine.  According to Dsanke, this is an issue with different BIOS structures. In Z170, it is "3MB Flash Descriptor + ME Region" and "5MB BIOS Region", while in Z370, it is "2MB Flash Descriptor + ME Region" and "6MB BIOS Region". If the system reboots or turns off with power, the NVRAM part in the BIOS will be messed up. Dsanke has a very detailed "readme" in Chinese about how to flash this BIOS, which the repository on GitHub doesn't have. For reference, http://www.smxdiy.com/thread-3097-1-1.html  I confirmed this last week (in a hard way). Flash it with a ch341a programmer, or flash it in OS and then cut the power.😉   1 Clevo P775DM2-G | i9-9900K (-150 mV undervolted) | RTX 2080 MXM3.1b | 330W PSU | TM heatsink with Honeywell PTM 7950-SP | 4x 8GB 2400MHz RAM | 2x 1T Samsung 970 EVO Plus, 1x 2T Samsung 870 EVO | BIOS 1.07.29, migrated from Z370 by Dsanke | Windows 10 Edu Link to comment Share on other sites More sharing options...
