red9350 Posted September 12, 2024 Share Posted September 12, 2024 On 5/24/2024 at 3:34 PM, runix18 said: Here is the bios. As for the mutant CPU you do not need to isolate any pins. P7xxDM3_ME_Disabled.zip 3.68 MB · 2 downloads I'm in the exact same situation as the OP, should i flash this file to the ME chip i wrongly flashed, or to the actual BIOS chip? Link to comment Share on other sites More sharing options...
red9350 Posted September 12, 2024 Share Posted September 12, 2024 Also.. the flasher i'm using is a SkyPro 2 but it's not detecting the GD25B64CSIGR chip.. It's not even in the database! Should i get another flasher? Link to comment Share on other sites More sharing options...
papjco32 Posted September 12, 2024 Author Share Posted September 12, 2024 here is stock bios, use 7zip to extract bios new mobo 64mbit.7z.001 bios new mobo 64mbit.7z.002 Link to comment Share on other sites More sharing options...
papjco32 Posted September 12, 2024 Author Share Posted September 12, 2024 and here is my back up of the chip, pretty sure its the me chip, mine was a winbond branded chip new mobo usb winbond 8mbit.bin Link to comment Share on other sites More sharing options...
red9350 Posted September 14, 2024 Share Posted September 14, 2024 On 9/12/2024 at 10:58 PM, red9350 said: Also.. the flasher i'm using is a SkyPro 2 but it's not detecting the GD25B64CSIGR chip.. It's not even in the database! Should i get another flasher? If someone from Google stumbles upon this post, i fixed it by connecting the laptop to the power supply, then trying to identify the chip with the SkyPro, and selected GD25Q64C from the list Link to comment Share on other sites More sharing options...
grisevg Posted May 5 Share Posted May 5 So QTJ1 can only work on "ME_Disable"/"-128G" bios on P775DM3? No way for it to work on ME-enabled bios? ME_Disabled means I'd lose TPM2.0? Link to comment Share on other sites More sharing options...
