Clevo p870tm issue
Maro97
Does the laptop behaves normal in its operation?
Desktop - MSI X670E Tomahawk Wifi (cheap Ebay mobo that I fixed) | AMD 7800X3D | 32 GB Trident Z5 Neo RGB 6000Mhz | MSI RTX 4070TI Suprim X  | Alienware 27 AW2724DM 2K 165 Hz Gsync | Samsung 990 Pro Nvme - Boot | Other various storage | Windows 10 Pro x64
Does the keyboard has any physical damage to the rgb ribbon cable? If not, it could be that the secondary EC is corrupted. You could reflash the EC but ONLY if you know what you are doing. An EC brick means a mobo brick so only reflash as a last resort.
Should be flashed with battery in. The collors of the keyboard are controled by the second EC not the primary one. Also you have an older dsanke bios moded by a russian moder from 4pda forum.
Reflash both EC and revert to last version stock bios.
After that you can reflash the lastest unlocked TM bios (but please flash the bios with a programmer not by ftp).
Flash both EC trough stock method.
Flash stock bios by stock method/SPI.
Flash dsanke (or any custom bios) only by SPI.
Just now, Maro97 said:
and i have P870TM-0716-9900KS-128G bios can i use it with 8700k & 32gb ram & gtx 1070 ?
Yes you can.
In the video you posted there are 2 EC. one primary 1.07.10 (but from what i know 1.07.09 is the last stock EC) and 2nd EC 1.05.03.
