Octane257 Posted June 8, 2024 Share Posted June 8, 2024 I am running windows 10 64 bit and I tried installing it but it’s not showing in system tray, desktop or loading when I find the program files where it’s installed Am I using the wrong version? Clevo W150HRM i5-2520M/8GB/GT 555M/ Link to comment Share on other sites More sharing options...
Pfudaniel Posted June 9, 2024 Share Posted June 9, 2024 You are using the wrong version Link to comment Share on other sites More sharing options...
crz Posted June 10, 2024 Share Posted June 10, 2024 21 hours ago, Pfudaniel said: You are using the wrong version This is a pretty old using Sandy Bridge CPU laptop model, which version of the clevo control center will work and where to find it in this a particular case? Link to comment Share on other sites More sharing options...
Pfudaniel Posted June 10, 2024 Share Posted June 10, 2024 23 minutes ago, crz said: This is a pretty old using Sandy Bridge CPU laptop model, which version of the clevo control center will work and where to find it in this a particular case? Good question i checked palkeo there is non for this model laptop. He can try older versions like 2.0 or some from https://my.hidrive.com/share/yze8mg-wf8#$/Drivers Laptops/CLEVO Control Center ( Hotkey ) Software Link to comment Share on other sites More sharing options...
