ccvortex Posted July 12, 2024 Posted July 12, 2024 Just spoke with DELL and they no longer sell USB recovery devices, so how am I supposed to get a full recovery USB with the OS and DELL drivers integrated? They keep pointing me to the Win recovery process but are leaving out how to get the DELL drivers integrated into it. I know the DELL stuff needs to be installed in a particular order so would like an all-in-one solution. Any help is appreciated.
ccvortex Posted July 12, 2024 Author Posted July 12, 2024 Let me expand on this. I want to do a full restore of my laptop back to factory. DELL is saying they don't sell/have anything that can do this, so I am left with this: https://www.dell.com/support/kbdoc/en-us/000125230/how-to-create-and-use-the-dell-recovery-restore-usb-drive which apparently just makes a recovery point from your existing install (so it has to be in perfect working order, which mine is not) or a basic Windows recovery download/install with no DELL drivers.
David55 Posted July 14, 2024 Posted July 14, 2024 In case it is worth anything, here is my low skill, ignorance based, two cent experience with the M6700. For windows 7, I used to fresh install windows with the precise Dell drivers (downloaded to USB) in the recommended order. Beginning with windows 10, I just let windows install whatever drivers it thinks I need and it has worked fine. The only thing missing is a utility for changing features of the keyboard, trackpad, and pointer nub. Don't even know if Dell still provides it anywhere.
Aaron44126 Posted July 14, 2024 Posted July 14, 2024 I agree more or less, these days I find it fine to do the base Windows install, get it online (install Ethernet or Wi-Fi driver), and let Windows Update take care of everything. I think that it will get every single driver. I'd still install the GPU drivers from Dell, and maybe some extra non-driver stuff like Dell Optimizer if you think you actually need it. Apple MacBook Pro 16-inch, 2023 (personal) • Dell Precision 7560 (work) • Full specs in spoiler block below Info posts (Windows) — Turbo boost toggle • The problem with Windows 11 • About Windows 10/11 LTSC Spoiler Apple MacBook Pro 16-inch, 2023 (personal) M2 Max 4 efficiency cores 8 performance cores 38-core Apple GPU 96GB LPDDR5-6400 8TB SSD macOS 15 "Sequoia" 16.2" 3456×2234 120 Hz mini-LED ProMotion display Wi-Fi 6E + Bluetooth 5.3 99.6Wh battery 1080p webcam Fingerprint reader Also — iPhone 12 Pro 512GB, Apple Watch Series 8 Dell Precision 7560 (work) Intel Xeon W-11955M ("Tiger Lake") 8×2.6 GHz base, 5.0 GHz turbo, hyperthreading ("Willow Cove") 64GB DDR4-3200 ECC NVIDIA RTX A2000 4GB Storage: 512GB system drive (Micron 2300) 4TB additional storage (Sabrent Rocket Q4) Windows 11 Enterprise LTSC 2024 15.6" 3940×2160 IPS display Intel Wi-Fi AX210 (Wi-Fi 6E + Bluetooth 5.3) 95Wh battery 720p IR webcam Fingerprint reader Previous Dell Precision 7770, 7530, 7510, M4800, M6700 Dell Latitude E6520 Dell Inspiron 1720, 5150 Dell Latitude CPi
