sala7blade Posted July 30, 2024 Posted July 30, 2024 Hi , So I have Alienware m17x 880M i74910MQ 240W 120hz display window10. Wanted to upgrade it to gtx1060 here is what I did:- SSD Already on GPT unlocked the bios set the video mode to PEG Installed the new gpu (1060) then restart didn't boot gave me 8 beeps and black screen boot mode set to uefi it booted after couple tries the only step now needed is a modded driver <--- I'm not sure if I did this right I get the above message, when I went to device manger, I selected show hidden devices (cuz Display Adapters was not showing)and it showed 880M transparent I uninstalled it thinking that I would help me install 1060 instead then the Display Adapters gone forever. tried restart many times no good , the GPU is detected in bios tho, however not in device manger anymore I don't know where to go from here? Any support would be appreciated Thank youÂ
Jerryzago Posted July 30, 2024 Posted July 30, 2024 All the steps are correct. Use DDU to remove any drivers in the system. Use Nvcleaninstall software to install the Nvidia driver. Alienware M18x R2 / i7 3720qm -> i7 3940XM / Dual 7970m -> 980m SLI -> HP Quadro RTX 3000 Alienware 17 R1 / 4710MQ -> 4930mx / 880M GTX -> PNY Quadro RTX 3000 HP 8570w / i7 3820qm / Quadro K2000M HP DV6500 / i7 T7200 -> i7 T9500 / 2GB RAM -> 4GB RAM / Atlas OS
Naberius Posted August 2, 2024 Posted August 2, 2024 After modding the driver, you'll need to restart with driver signature enforcement disabled. Then you "should" be able to proceed with installation. If it's still giving you trouble, please post which guide and steps you undertook to mod the driver. The process hasn't changed in... like a decade... but different guides are easier to follow than others. AW M18 R1 | i9-13900HX | RTX4090 | 64GB DDR5Â AW M17XR4 | i7-3940XM | GTX1070 | 32GB DDR3 AW M15X | i7-940XM | GTX970m | 16GB DDR3 Formerly Schurke of NBR and TechInferno
