Hello everyone, I want to install a working Tesla M6 in my 17 R1. But it refuses to be displayed in the BIOS even, I think that I need to try to flash a modified VBIOS for 980M.
This:https://www.techpowerup.com/vgabios/244249/244249.
But I can't do it with nvflash on the laptop where it starts. It gives an error of some kind of incompatible PCI id Device. It seems that I need to flash it with a programmer. But I can't do this because of the low-profile BIOS chip on the video card. My Ch341a programmer with a clip can't hook on - I don't want to unsolder the chip. I have a question, maybe there are some other programmers that can flash this chip without removing it?
here is a photo of the BIOS chip for comparison with the 980M
upgraded from: GTX 1070 Oc`d, Quadro P4000 Oc`dTesla M6 Oc`d
In past lives:
Tesla M6 should be detected in the bios without problems, at least in my m17x r4 it was fine. However, it can only work in optimus mode because the native bios has no video outputs.
As for re-flashing vbios for this card - it doesn't work, even with the chip itself unsoldered. at least I read about it once, but unfortunately I couldn't find the link quickly.
Regarding the fact that it does not have video outputs and only SG mode will work - of course I know, it worked for me on my M18x R2, but on the 17 R1 it refuses. The question is, why can't vbios be flashed? I flashed it using nvflash with some certificates when I overclocked it. Why then won’t it be possible to reflash it? I can’t simply attach it with a clip, I can’t reach the contacts. I think that the chip is reflashable with 99% probability, since we reflashed it with Nvflash and everything worked.
In past lives:
Well, if you managed to flash it with nvflash then no problem - take for warranty version of the program with bypass protection against flashing and flash it on a laptop that sees the video card.
as far as I know this is the latest vbios for it:
https://www.techpowerup.com/vgabios/225011/225011
earlier versions are not desirable
  • 6 months later...
TESLA m6 CANNOT WORK IN AW 17 r1! I confirm that, not detected in Bios at any reason (flashed 10 vbioses from tesla\gtx980m\quadro m5000m). Do not try. 0 results
I can confirm, I had no luck in one of my 17's when I tried a few years ago. I thought it would be the same in all machines so I never tried an M17x or M18x. Wish I had now.
