Alienware 17 R1 upgrade to 1070 or P4000 with 60Hz display
So i have an Alienware 17 R1 with a GTX 980M and 240W PSU. The GPU recently started crashing the entire computer during gaming and sometimes it wouldn't totally crash but give me Nvlddmkm error and after a restart disappear from the device manager and then require some restarts to get it back to show.
So now im
looking to upgrade to a better card. I have the 60Hz display. Is it possible to upgrade to a 1070, a P4000 or any other better card without having to go with the 120Hz display?
So now im
hi,
yes you can upgrade easily with the 60Hz screen, as you have NVIDIA OPTIMUS.
Best options are 1060 gtx (~150€), 1070 gtx (~200€), or even quadros P3000/4000/5000. You can even go with 2060 RTX (quadro rtx 3000) but it ain't cheap (350€+).
Changing screen to an EDP screen would reduce the spectrum of options (as cards absolutely need good vbios with edp activated) but would give you a much better screen than the old TN 60Hz LVDS, altough a lesser battery life (as optimus is inhibited).
you know where i can find the unlocked bios? I found a post about the Alienware 17 R1 Ranger. Is the Ranger a different model? Mine is just Alienware 17 R1
