Hi plz I need some help i found used msi titan gt80 (i7 5th gen/gtx 980m sli) then can I scavenge the gpus to upgrade my dead gtx 970m on  CLEVO P751DM-G are they compatible i need help to make the purchase or not.
I think it will work, because MSI GT80 has EDP, like your Clevo. and the video card supports EDP. I know that it was successfully installed in Alienware M18x R2 without any problems, so I think you won't have any problems either, except whether the video card will fit in the case and whether everything will fit on the heatsink.
Alienware M18x R2: i7-3920XM @4.7 GHz / 24GB DDR3-2133@CL11 / GTX 1070 Oc`d
upgraded from: Quadro P4000 Oc`dTesla M6 Oc`d
In past lives:
but you still have to either manually install the driver through the device manager or modify the driver, I think you understand this.
In past lives:
