ssj92 Posted December 28, 2024 Posted December 28, 2024 I bought a M6600 for parts the seller claimed MB is probably dead. wanted to ask here in case it’s a dumb issue. AC charger doesn’t cause any lights to turn on. Pressing power button does nothing. I checked to make sure ram is installed, cmos battery cpu etc. any other trick I can try before I end up replacing the MB? I have a M6800 coming that has a battery so I’m going to try its battery in here in case the dc port is messed up or something. Alienware Area-51M : Intel Core i9-9900K @ 5.3Ghz | nVidia GeForce RTX 2080 | AX210 | Samsung 970 Evo+ Alienware M18x R2 : Intel Core i7 3920XM @ 4.7Ghz | nVidia GeForce RTX 3080 | AX210 | Samsung 980 PRO Alienware 18 : Intel Core i7 4930MX @ 4.5Ghz | nVidia Quadro RTX 5000 | AX210 | Samsung 980 NVMe More Laps: M14x | M14xR2 | M15x (980m) | M17xR2 (RTX 3000) | M17xR3 (WX 7100) | M18xR1 (RTX 5000) Precision 7520 (T1000) | 7720 (Tesla P6) BEAST Server: Intel Xeon W7-3465X 28 P-Cores | 2x nVidia RTX Titan | 128GB RDIMM | Intel Optane P5800X CS Studios YouTube: https://www.youtube.com/c/CSStudiosYT
JadeRover Posted December 28, 2024 Posted December 28, 2024 Hi, if you don't have a multimeter, maybe go see a local tech repair shop. If they are professional and good at their job, they should have a diagnostic fee (probably 10-20 dollars/euros/ or equivalent) they can look and see if it is an easy problem such as a shorted capacitor (best case scenario and possibly a common fault as the computer is old) and they can quote you the price to repair motherboard (could be cheaper than buying a new one). If you have a multimeter and some electrical knowledge (and are willing to invest a little time) I would recommend doing basic checks such as removing motherboard from laptop and try to power it on with nothing else connected, check for shorted power in cable, shorted main power rail, shorted mosfet, no 3.3v on power button, piece of metal fallen on the motherboard, water damage... A ressource you can look at is this beginners guide by Louis Rossmann. https://docs.google.com/presentation/d/1PkeO_lC5WTPScSV3ZzEEjVuDWeQtL2eHK6jEcf7axA0/mobilepresent?slide=id.gb813305ed3_143_1167 it's a bit basic and childish at times but it gets the point across. Other laptop repair resources are on the internet and can teach you basic tests. Keep in mind the fault can be as simple as disconnected ribbon cable, small piece of corrosion, dead charger, etc... I resurrected a "totally dead motherboard for parts" ThinkPad l430 that just had a screw touching power button ribbon cable on the keyboard that prevented it from turning on. 1 Precision M6700 : i7-3740QM | P3000 6gb engineering vbios | 20gb DDR3 1600Mhz | FHD ips dreamcolor | delta fans Zbook 17 g3 : i7-6820HQ -75mv | M3000m 4gb | 16gb DDR4 2400Mhz | FHD ips Precision 7720 : i7-6820HQ -80mv & 102.7mhz BCLK| Zotac GTX1060 6gb, 100w OC vbios | 16gb DDR4 2666Mhz | (crappy) FHD ips -> 1440p165hz upgraded Zbook 17 g5 : i7-8850H, -140mv | P5200 16gb | 32gb DDR4 | FHD IPS
ssj92 Posted January 4, 2025 Author Posted January 4, 2025 Well after removing everything up until the RAM it magically started booting up. I switched the RAM with some other modules I had. Power board cable got ripped during disassembly but now it's working at least Alienware Area-51M : Intel Core i9-9900K @ 5.3Ghz | nVidia GeForce RTX 2080 | AX210 | Samsung 970 Evo+ Alienware M18x R2 : Intel Core i7 3920XM @ 4.7Ghz | nVidia GeForce RTX 3080 | AX210 | Samsung 980 PRO Alienware 18 : Intel Core i7 4930MX @ 4.5Ghz | nVidia Quadro RTX 5000 | AX210 | Samsung 980 NVMe More Laps: M14x | M14xR2 | M15x (980m) | M17xR2 (RTX 3000) | M17xR3 (WX 7100) | M18xR1 (RTX 5000) Precision 7520 (T1000) | 7720 (Tesla P6) BEAST Server: Intel Xeon W7-3465X 28 P-Cores | 2x nVidia RTX Titan | 128GB RDIMM | Intel Optane P5800X CS Studios YouTube: https://www.youtube.com/c/CSStudiosYT
