bought a new MSI U12A I think. Need help finding power setting to keep system on while lid is closed to use external monitor
We bought our son a new MSI 15 inch gaming laptop.  I cannot find the setting to change to keep the system on while the lid is closed to use an external monitor.  any help would be appreicated
Damn, I am dumb.  Never thought of that.  Thanks!
Worked like a charm.  Thanks again.
  • 4 weeks later...
Maybe stating the obvious but I recommend to keep the screen just a bit open as temps will be better. I usually shoot for two ca. 1 to 1.5" foam pieces at the front to create a gap where the warm air from the keyboard deck can get out. I am doing that with all my laptops when their screen isn't used and it certainly makes a difference.
