Sycorexx Posted January 5, 2025 Posted January 5, 2025 Hoping to learn something new alongside my son. Iām mechanical and a part time manual machinist but barely know my way around an iPhone. If youāre offended by a lack of knowledge youāre going to hate seeing my posts. in my field Iām known as a master franckenstiener and fab shop. I have a love for making crazy combos look factory. also known for bringing centuries old machines back to work, so thereās a pattern to my dimensia. Everything I do is cheaper than a college education, thatās my philosophy about the money. Iām not looking for a good but cheap laptop Iām looking to see with my own eyes how and why a laptop works or/and doesnāt.Ā I bought a 7720 with a 6820 chipset. I also bought a motherboard with a Xeon 1575 chipset and some ābadā motherboards so I can work my way around and see how the power flows. (Hereās where I go crazy). live read 7750ās boards port out the back so theyāre not compatible with a 7720 chassis. BUT theĀ Intel Xeon W-10885M chip has 8 cores but a lower idle mhz. Both chips take the same socket, question is would all the drivers work if the only thing swapped is theĀ Intel Xeon W-10885M onto a 7720 motherboard? This isnāt about the money, itās about the education. I will be looking for a shop thatās willing to help in these endeavors so if you know any hot rodders out there please point me in their direction.Ā Thanks guys, Dean
Aaron44126 Posted January 5, 2025 Posted January 5, 2025 You are right that these CPUs use the same "socket" ā though "socket" is a bit of a misnomer because the chips aren't removable from the motherboard without microsoldering work.Ā You'd need someone who knows what they're doing to make the chip swap. Ā You're also right that Precision 7750 boards won't fit in a 7720.Ā At this time Dell was doing an "every other generation" chassis refresh ā so you can use (most) 7710 components in a 7720 (and vice versa), and 7730/7740, and 7750/7760, and 7770/7780, but if you go outside of those pairings then things get a lot more hairy. Ā But the CPU socket is the same still.Ā Would it work if you swapped them?Ā Wish I could say.Ā I've seen chatter about "attempting" this sort of thing before but I've never heard from anyone who actually tried it.Ā Drivers shouldn't be a problem, the only "driver" that would really be different would be the Intel integrated GPU driver and you could grab that one from the Precision 7750 support site (or, Windows Update would probably pull it down automatically). Ā There could be other reasons that this would not work.Ā Will the Precision 7720 BIOS throw up if it encounters an Intel 10th-gen CPU?Ā Will the 10th-gen Xeon be happy to talk to the older PCH in the 7720?Ā Are there actually changes or additions to the CPU pinout between these different generations that we don't know about? Ā On desktops you can generally assume that any CPU that "fits" into a socket will be compatible with whatever motherboard.Ā (Sometimes a BIOS update is necessary to fully support new CPUs in an old motherboard.)Ā On the laptop side, the engineers are able to assume that you'll only ever use the system in the configurations that they ship out of the factory, so they probably didn't take any steps to support and definitely did not test "new CPUs in an old system". Ā And because of the physical difficulty in making the chip swap, it's not a common thing to mess around with even for us tinkerers. Apple MacBook Pro 16-inch, 2023 (personal) ⢠Dell Precision 7560 (work) ⢠Full specs in spoiler block below Info posts (Windows) ā Turbo boost toggle ⢠The problem with Windows 11 ⢠About Windows 10/11 LTSC Spoiler Apple MacBook Pro 16-inch, 2023 (personal) M2 Max 4 efficiency cores 8 performance cores 38-core Apple GPU 96GB LPDDR5-6400 8TB SSD macOS 15 "Sequoia" 16.2" 3456Ć2234 120 Hz mini-LED ProMotion display Wi-Fi 6E + Bluetooth 5.3 99.6Wh battery 1080p webcam Fingerprint reader Also ā iPhone 12 Pro 512GB, Apple Watch Series 8 Ā Dell Precision 7560 (work) Intel Xeon W-11955M ("Tiger Lake") 8Ć2.6 GHz base, 5.0 GHz turbo, hyperthreading ("Willow Cove") 64GB DDR4-3200 ECC NVIDIA RTX A2000 4GB Storage: 512GB system drive (Micron 2300) 4TB additional storage (Sabrent Rocket Q4) Windows 11 Enterprise LTSC 2024 15.6" 3940Ć2160 IPS display Intel Wi-Fi AX210 (Wi-Fi 6E + Bluetooth 5.3) 95Wh battery 720p IR webcam Fingerprint reader Ā Previous Dell Precision 7770, 7530, 7510, M4800, M6700 Dell Latitude E6520 Dell Inspiron 1720, 5150 Dell Latitude CPi
Sycorexx Posted January 5, 2025 Author Posted January 5, 2025 Thanks for the reply. Ive bought some bad motherboards to practice cpu swapping. Once I get semi confident Iāve got it down Iāll buy one in working condition and do a swap and test it. Eventually Iāll get to attempting an actual set up.Ā
