rocas Posted February 28, 2022 Posted February 28, 2022 Good morning guys, looking at a NBR thread of SSJ92, I purchased this AX210.https://www.ebay.ch/itm/174539670808 Now the drivers I see them installed and the Bluetooth works well, I tried with Xbox Elite 2 controller. The problem is in wireless. In settings, see photo, I find the wifi always off, From active switch settings, wifi I see it turned on, I leave settings, wifi returns back off. Thank you! of your advice. Â Â Â
StripeySnake Posted February 28, 2022 Posted February 28, 2022 There should be a button a the top right, right above the keyboard with a wifi icon that toggles wifi on and off for the computer. You might want to try turning it off and on there, and/or making sure it's enabled via that button. Good luck. Daily Drivers: JANKTOP IV Mini-ITX Laptop - R5 2600X, 16gb DDR4 3000 Mhz, RX 5700 XT - (ONGOING) Claymore V2 Cyberdeck, 6900HX, 680m iGPU, 16gb DDR5, 185 Wh Battery 14 R1 - 4710MQ @ 3.6 Ghz, hd 4600, 12gb DDR3L 1600 Mhz Past Projects: 15 R3 - GTX 1060 6gb, i7 7700HQ, 16gb DDR4 17 R4 - RX 470 8gb i7 6700HQ, 16gb DDR4 M17x R4 - 3630QM, Quadro P4000, 16gb DDR3L 1600 Mhz M17x R2 - i7 920XM @ 3.4 Ghz, GTX 770m 2gb, 16gb DDR3
rocas Posted February 28, 2022 Author Posted February 28, 2022 18 minuti fa, StripeySnake ha detto: Dovrebbe esserci un pulsante in alto a destra, proprio sopra la tastiera con un'icona wifi che attiva e disattiva il wifi per il computer. Potresti provare a spegnerlo e riaccenderlo e/o assicurarti che sia abilitato tramite quel pulsante. Buona fortuna. Â Thanks for your answer, I tried but it doesn't work, Change to plane mode. As a router I have an ASUS RT-AC66U. Â Â Â Â Â doesn't work,Â
StripeySnake Posted February 28, 2022 Posted February 28, 2022 Unfortunately, I don't have any experience with m.2 wifi cards in legacy machines. Good luck, and I hope you find someone who can be of more help. Daily Drivers: JANKTOP IV Mini-ITX Laptop - R5 2600X, 16gb DDR4 3000 Mhz, RX 5700 XT - (ONGOING) Claymore V2 Cyberdeck, 6900HX, 680m iGPU, 16gb DDR5, 185 Wh Battery 14 R1 - 4710MQ @ 3.6 Ghz, hd 4600, 12gb DDR3L 1600 Mhz Past Projects: 15 R3 - GTX 1060 6gb, i7 7700HQ, 16gb DDR4 17 R4 - RX 470 8gb i7 6700HQ, 16gb DDR4 M17x R4 - 3630QM, Quadro P4000, 16gb DDR3L 1600 Mhz M17x R2 - i7 920XM @ 3.4 Ghz, GTX 770m 2gb, 16gb DDR3
rocas Posted March 1, 2022 Author Posted March 1, 2022 Then it doesn't work in the slot where DMC / SIBEAM is installed, See this video ssj92 . https://www.youtube.com/watch?v=0QV0OuOOMC-Q. I tried to insert the card into the Half Mini PCIe slot, (holding the diagonal card since we don't have SPACE). And it works perfectly. In the search errors he tells me to turn on the wifi. In BIOS, wireless, DMC and Bluetooth are enabled. Maybe something escapes me to activate in the BIOS? ideas? The only thing different from the video, I removed the Killer 1103 card.
rocas Posted March 1, 2022 Author Posted March 1, 2022 Â Guys I managed to solve. After replacing the WiFi module in the Full Height Mini PCIe slot, The WiFi radio remains off. I show you as I did, so as to help other people. With Intel AX210 card you need to cover the following PINs, see photo. Â Â Â Video Link Procedure Half Mini PCIe card, Â Video Link Various Procedure Model Cards https://thecomputerperson.wordpress.com/2016/11/04/how-to-mask-off-the-wifi-power-off-pins-on-m-2-ngff-wireless-cards-the-old-mini-pci-pin-20-trick/ Â Â
StripeySnake Posted March 1, 2022 Posted March 1, 2022 Brilliant! Daily Drivers: JANKTOP IV Mini-ITX Laptop - R5 2600X, 16gb DDR4 3000 Mhz, RX 5700 XT - (ONGOING) Claymore V2 Cyberdeck, 6900HX, 680m iGPU, 16gb DDR5, 185 Wh Battery 14 R1 - 4710MQ @ 3.6 Ghz, hd 4600, 12gb DDR3L 1600 Mhz Past Projects: 15 R3 - GTX 1060 6gb, i7 7700HQ, 16gb DDR4 17 R4 - RX 470 8gb i7 6700HQ, 16gb DDR4 M17x R4 - 3630QM, Quadro P4000, 16gb DDR3L 1600 Mhz M17x R2 - i7 920XM @ 3.4 Ghz, GTX 770m 2gb, 16gb DDR3
ssj92 Posted March 3, 2022 Posted March 3, 2022 For the future I highly recommend people get the updated mini pcie card format instead:  https://www.ebay.com/itm/255111905218?_trkparms=ispr%3D1&hash=item3b65dabfc2:g:47QAAOSwDclhKd3F&amdata=enc%3AAQAGAAACkPYe5NmHp%2B2JMhMi7yxGiTJkPrKr5t53CooMSQt2orsSg3Ye8yTWgOW7pmE1t838dogBwDBnL6PmMuFx9hEhMq0qwptEIvdzNJJ5szouz42KaVjHELTouvuNPLZ0XOeufa9JutitmJohHhrMYdXua8zpDpoewMKAoy74mYl5gYdgUqpW8YA52SqrkL2gynaYO31PesAQ6%2B55f0mZgyq4TuG4cFW8dsoEx7yUy5pC5foEzrSR3concnQv%2FE61cO5Sr4LPVAcTyCgZuIPLqTKaHm5rCSXRF9DG3y3keAtTLeh8MoUgqwZuthvTF6pKoW0qOoGM2dL0HQioGJ8TSorUTEhLMyHF6jlLRl%2FqH9xthZtkY5jErFA8a4S2bZGyHdCEkaTMRTof950HeycGi5puLjXgSCnNyaBXqxnYssY4gJyLUolY3toYibAaYj2VGAy7NmqSGQPpdp8MuhqmwiILVIIqh9yunl6DGWSisYsi%2FpSRlkLp3vo1pr7gb9BD4ael6fwKduaPOTdBLPTtTbdm7mPI%2B%2F7ITyEDwfvdMu3T5ez4FtqL4pXRrJUo5hEXhlk8paOemQf28RxylWq1NCzs8a5p%2FVneIV5janbWqcHaGAAc7M4CQYhYCmaWp7XmAhmHGh4wsn7sbeEEo%2BJ4ohoFoarXFqJGFNSaVJ8trXoD5F75yLY4DbOQzxfucwNT0MRIaj%2BImwr%2FirzgIkqRg3Zdp1RgEsgMy12eYB9phxznuApuHPn7L4IAe5iGO%2BQMAUYR2CoilwxTueDmmvag%2BMkIH4%2FbB%2FCMtcjIKK6uhej%2B44haFeIlmwp2z4sTmTVLvF%2F9C4r50dretq8CAGOadORruA8STE2N%2FtgxXBRN%2Bx0paIZu|clp%3A2334524|tkp%3ABFBMsuCO1-lf  or  https://amzn.to/3tnCjW4 Alienware Area-51 18 : Intel Core Ultra 9 275HX @ ???  | nVidia GeForce RTX 5090   | BE200 | 1TB Gen5 9100 PRO Alienware Area-51M : Intel Core i9-9900K @ 5.3Ghz   | nVidia GeForce RTX 2080   | AX210 | Samsung 970 Evo+ Alienware M18x R2 :  Intel Core i7 3920XM @ 4.7Ghz | nVidia GeForce RTX 3080   | AX210 | Samsung 980 PRO  Alienware 18 :        Intel Core i7 4930MX @ 4.5Ghz | nVidia Quadro RTX 5000  | AX210 | Samsung 980 NVMe  More Laps: M14x | M14xR2 | M15x (980m) | M17xR2 (RTX 3000) | M17xR3 (WX 7100) | M18xR1 (RTX 5000) BEAST Server:     Intel Xeon W7-3465X 28 P-Cores | 2x nVidia RTX Titan | 128GB RDIMM | Intel Optane P5800X CS Studios YouTube: https://www.youtube.com/c/CSStudiosYTÂ
