Dream Posted March 21, 2025 Author Share Posted March 21, 2025 Apparently, "there are no updates that would change XMP behavior" according to the reseller who contacted Prema. RIP. Link to comment Share on other sites More sharing options...
runix18 Posted March 21, 2025 Share Posted March 21, 2025 4 hours ago, Dream said: Apparently, "there are no updates that would change XMP behavior" according to the reseller who contacted Prema. RIP. Then manualy ajusting XMP setting are your best bet. Desktop - MSI X670E Tomahawk Wifi (cheap Ebay mobo that I fixed) | AMD 9800X3D | 64GB Corsair Vengeance RGB DDR5 6000MHz CL30 Dual Channel Kit | MSI RTX 4070TI Suprim X | Alienware 27 AW2724DM 2K 165 Hz Gsync | Samsung 990 Pro Nvme - Boot | Other various storage | Windows 11 Enterprise x64 SOLD - Clevo P870DM-G | i9-9700K 4.5 Ghz on all cores (-50 mv undervolted) | 32GB Hyper X Black 2666MHz | Clevo RTX 2080 3.1b undervolted for better temp 1905Mhz @881 mv | AUO B173HAN03.1 144hz Gsync | Samsung 980 NVME | Dsanke TM BIOS - Chujoi13 adapted based on needs | Network Card: Intel AX210-AX | Windows 10 Pro x64 Link to comment Share on other sites More sharing options...
Dream Posted March 21, 2025 Author Share Posted March 21, 2025 9 hours ago, runix18 said: Then manualy ajusting XMP setting are your best bet. I mentioned before how I’m already using the “default XMP profile” by replicating it as a custom profile (and with slightly lower numbers on some as well; higher for tREFI) alongside the appropriate voltage at 1.35v, but the DRAM is still not at 1600 MHz. It’s been stable at the default 1333 MHz. The sticks were supposed to be new as sold and shipped by Amazon. What’s a good stress test for it these days just to see if it can hit the higher frequency? EDIT: Also, apparently Prema has no updated BIOS for what I have. Link to comment Share on other sites More sharing options...
runix18 Posted March 22, 2025 Share Posted March 22, 2025 15 hours ago, Dream said: I mentioned before how I’m already using the “default XMP profile” by replicating it as a custom profile (and with slightly lower numbers on some as well; higher for tREFI) alongside the appropriate voltage at 1.35v, but the DRAM is still not at 1600 MHz. It’s been stable at the default 1333 MHz. The sticks were supposed to be new as sold and shipped by Amazon. What’s a good stress test for it these days just to see if it can hit the higher frequency? EDIT: Also, apparently Prema has no updated BIOS for what I have. I use Aida 64 and/or OCCT. Desktop - MSI X670E Tomahawk Wifi (cheap Ebay mobo that I fixed) | AMD 9800X3D | 64GB Corsair Vengeance RGB DDR5 6000MHz CL30 Dual Channel Kit | MSI RTX 4070TI Suprim X | Alienware 27 AW2724DM 2K 165 Hz Gsync | Samsung 990 Pro Nvme - Boot | Other various storage | Windows 11 Enterprise x64 SOLD - Clevo P870DM-G | i9-9700K 4.5 Ghz on all cores (-50 mv undervolted) | 32GB Hyper X Black 2666MHz | Clevo RTX 2080 3.1b undervolted for better temp 1905Mhz @881 mv | AUO B173HAN03.1 144hz Gsync | Samsung 980 NVME | Dsanke TM BIOS - Chujoi13 adapted based on needs | Network Card: Intel AX210-AX | Windows 10 Pro x64 Link to comment Share on other sites More sharing options...
ShifflyTheSHO Posted March 24, 2025 Share Posted March 24, 2025 On 3/3/2025 at 9:18 AM, ShifflyTheSHO said: I foolishly ordered these because I want to fill all DIMM slots for my i9-9900KF. https://www.amazon.com/gp/aw/d/B09NLCG8NJ?ref=ppx_pt2_mob_b_prod_image and is the P750DM3 radiator the exact same as the P770DM or P775DM3? I’m going to shoot my shot on a used one but just wanted a confirmation instead of reading conflicting pages. Heatsink tag say 6-31-P75D3-302 (GTX 1070m), and I keep finding that part number on 17” models with the 1070. i take back what I said. That kit was amazing and I WANT THEM BACK! (CL18, 3200mhz) Does anybody know how get my 4 sticks of RAM back to 3200mhz? —— I had this CMS 3200mhz CL16 4x8GB kit off of Amazon that I returned, but I was running CL18 with stability at some timings at 3200mhz!!, but forgot what I adjusted on my motherboard (Z170) or my processor (i9-9900kf) I’m trying to get back to 3200mhz so O can have some bandwidth again, and everybsetting I try drops me back to 2400mhz in the Windows environment. It was my first attempt at overclocking RAM and it was a grand slam! I got mad and returned them and I’m running a mixed kit of Micro CL22 and unknown cheap set that used to shut off my computer, but I split the kits up onto separate channels and I’ve been at a nice, stable 2400mhz. I DO NOT WANT TO RUN 4 STICKS!!! That is so much slower on startup and in everything else; why do people only run 2 of 4 kits when manufactures gave you four and they out perform anything else with two slots? Its like driving high revving sports car with donuts on the drive wheels. But anyways, do I need to adjust anything beyond the SA and IO voltage? I can no longer seem to go beyond 1100 mV (1.1 V) on either without my system being caught in a loop. How do I adjust the memory controller properly? I change the latency and set it to relearn, but should I try for 3033mHz? dsanke BIOS, and my keyboard is off currently from having to pull the CMOS so many damn times. (my processor can also undervolt to -0.150. Should I not?) Link to comment Share on other sites More sharing options...
ShifflyTheSHO Posted March 24, 2025 Share Posted March 24, 2025 Never mind, I set it to auto in the multiplier and bumped the offsets by four (.070v, 70mv). CL22 is doing okay! Is it possible to tighten the timing s of non-XMP default RAM? Link to comment Share on other sites More sharing options...
ShifflyTheSHO Posted March 24, 2025 Share Posted March 24, 2025 4 hours ago, ShifflyTheSHO said: Never mind, I set it to auto in the multiplier and bumped the offsets by four (.070v, 70mv). CL22 is doing okay! Is it possible to tighten the timing s of non-XMP default RAM? sorry, its stock CL22 RAM but it’s running at CL18 from default learnings! Just like that $70 4x8GB RAM kit I was bragging about; so that was nothing special, just gussied up non-XMP ICs. I’m going see how far these timings can go now, brb. Link to comment Share on other sites More sharing options...
Dream Posted March 25, 2025 Author Share Posted March 25, 2025 22 hours ago, ShifflyTheSHO said: sorry, its stock CL22 RAM but it’s running at CL18 from default learnings! Just like that $70 4x8GB RAM kit I was bragging about; so that was nothing special, just gussied up non-XMP ICs. I’m going see how far these timings can go now, brb. What's the latest you got on your timings? I temporarily stopped adjusting mine because I don't have enough knowledge to understand why my DRAM isn't changing even after tweaking things in the BIOS. Link to comment Share on other sites More sharing options...
Dream Posted November 17, 2025 Author Share Posted November 17, 2025 Well, after months of not really being able to use the XMP profile (or a similar one as a custom profile) to get the 1600 MHz DRAM frequency, the sticks decided to just not work even with the stock profile. I contacted Crucial today, and they can't replace my 32 GB Ballistix kit anymore because it's an old one. I didn't ask them before since I was pretty tired and too annoyed at the purchase I made that's not reaching the speeds it should for my laptop. They offered this as a replacement: https://www.crucial.com/memory/ddr4/ct2k32g4sfd832a This should still work. Right? The CAS latency is definitely higher on this one though. It's better than nothing, I guess. Link to comment Share on other sites More sharing options...
