Timetec Pinnacle Konduit SODIMM 3333mhz (CL18 18-20-20-40, 2x16GB Dual Rank Hynix)
Its Baby-steps!!!, but considering laptops have like less than 8 options in and CL16 1.35v wouldn’t boot initially until I added slower memory and pulled that on reset (4 SODIMM slots!) wasn’t working on my Clevo, is this moderate enough, or since I had my normal CL22 Hynix and Micro here… at 3200mhz,
should I assume these ICs were the same ones at 3600mhz CL16 on desktop RAM?
Like, I will send it eventually, but I’d rather type all this before I go through my BIOS again to change all those settings back to 120hz CRT-fast!!
Samsung would only handle CL18 at 3200mHz and that includes the basic PNY ICs that were on there crappy, CL20 performance RAM that was regular 2666mhz RAM with a 1.2v flash  to the next higher level enabled by XMP, but Hynix has some good chips.  The two look Identical btw, but those Samsung/PNY made me think I corrupted my BIOS with how the overclock lost the data!
Also my Memory controller is set to +0.070 and will start overheating or crashing at possibly +0.090, but that was when I was running 4x16GB dual rank, so do I even need to up the MC any more now that the CL20 PNYs are gone?
I just had some Muskins too that didn’t post so I sent them back.  Did I mess up with buying these Timetec ICs at half the price of Muskins?
I have the voltage at 1.35v now too.
Newsflash:
3466mhz didn’t work at CL22 and now I have to clear my CMOS to reset all these setting in like, 40 different menus.
was I supposed to set it to “odd ratio” since I was running a an odd number?
I forgot to take pictures of all the settings too!!
