P870DM-G won't post. Turns on, no display, fans spin, then laptop powers off.
Hi,
A few years back my Clevo P870DM-G simply stopped working. No apparent reason. After doing all the usual troubleshooting and tricks, I simply gave up, stored it away and built a new SFF PC.
Anyway, I decided to try to resurrect this thing from the dead one last time.
++Same behavior as from the last time I tried it. Power brick has green light when plugged in. Plugging into laptop lights up the charger LEDs in the front. They are both orange at first but after a while it charges and the left battery LED turns green. I press power button, power button light turns on with the cool strobing effect, the front right LED turns green, keyboard lights up, no screen or post or any other activity beyond the lights for about 20 seconds or so, then the fans turn on full blast and they stay on for about 35 seconds straight and then the whole laptop powers itself off. And that's where's it's been the past several years.
I completely dissembled the laptop and reassembled. Tried one RAM stick, different slots, swapped out the 6700K wit ha different 6700K, swapped the 980GTX with another 980GTX, reset CMOS, swapped keyboard, etc.... nothing changed the above mentioned behavior.
Any suggestions? Would a BIOS rom flasher be something I should try? That is the one thing I never tried. I'm not familiar with them, so not sure if this is something that would require modding of some sort?
I do have two BIOS zip files for the laptop, a version 02 (original from the Prostar reseller at the time, emailed to me by one of their CS reps) and a version 08 (later version I found on the old Notebook Review website someone sent me), but I'm not sure what file inside it would be used with a flasher. Or even if that's worth trying. There's a bunch of files in each zip folder and they're meant to be launched from the OS itself. I posted a pic of both bios file folders if anyone can make heads or tails of them. I also still have all the driver files, if I can actually get this thing running again.
Anyway, any suggestions? It's been a few years but I have all the parts for it still intact and everything looks in pristine condition. Should I give a flasher a try? This isn't an emergency BTW - I'm just saddened such an awesome looking laptop doesn't work and I want to see if I can save it.
Thanks.
Buy a cheap ch341a bios flasher and try to reflash the bios. The file to flash with the programmer will be P870DMG.02
Ok, I'll give it a shot and report back.
Would something like THIS work? I never used on of these before.
Yep thats the one.
6 hours ago, runix18 said:
Yep thats the one.
Awesome. Cheap enough for me to try it out at least. The guy in the review video used software called NeoProgrammer 2.2.0.10 to operate the flasher. I'm guessing that would work? Is that easy to get? Not sure what the official site is for it. Or is there better software to use it to try to flash my Clevo board with it? Thanks again.
Try here.
9 hours ago, runix18 said:
Try here.
Got it. Now I'm just waiting for the programmer to be delivered this weekend.
BTW - I posted some questions in another thread, not sure if you can answer any for me?
1. Do I need to rename the BIOS file in any way to get them to work? Example, with the P870DMG.02 file, should I change the .02 to .ROM or .BIN? Also, do I need to convert them to different file types, or is just simply renaming the extensions good enough? Or will the programmer be able to use it as-is with no changes?
2. BTW - The BIOS chip I have is a Gigadevice BH1540 / 25B64CSIG - labeled on the top of it. That'll work with the programmer & NeoProg right?
3. Do I need to plug anything back into the motherboard before trying to flash it? Right now, I have the motherboard unplugged and removed from the case and all the hardware removed (SSDs, RAM, WIFI/BT chip, keyboard, laptop battery pack, CMOS BATTERY, GPU, etc...). Only thing still plugged in is the CPU.
I'm trying to get everything set up ahead of time to make sure I do it correctly. Thanks!
1. No
2. Yes
3. Motherboard unplugged is ok with or without Cmos battery.
PS make sure you put the jumper on the programmer like so
GuideHow-to-Use-CH341A-USB-Programmer-1.
1. No
2. Yes
Ok, thanks! I'll check back in after I get the programmer and try flashing the chip. Hopefully by the end of this weekend.
Not getting my hopes up too much. I haven't gotten this thing to POST since 2021.
UPDATE: - still won't POST after flashing the BIOS chip with the programmer.
The programmer worked fine. Detected the BIOS chip right away and it did have a BIOS already on it. I backed up/erased/flashed it anyway with the old stock BIOS file I had, reassembled the whole thing, hit the power button and it did the same thing as I mentioned above.
1. Plugged in power cable. Hit power button.
2. Power button light, Keyboard backlight, the two rear screen cover lights, and two front edge LEDs all light up and stay lit. The one front edge LED on the right turned green (when laptop is off, it's orange. When turned on, it's green). The charging LED (on left) was orange (battery wasn't fully charged yet.)
3. Nothing displayed on the monitor screen. No response to keyboard or touch panel clicks. No response to CAPs or NUM lock toggle.
4. Nothing else happened for about 30 seconds.
5. After 30 seconds, the fans turned on full blast and they ran for about 30 seconds.
6. Then the whole laptop turned itself off.
Same behavior as before. I tried booting it up 2 more times, but same exact result.
The good news is that we can rule out a bad BIOS or BIOS chip.
The bad news is that I still don't know why it won't get to the POST screen.
There's no obvious damage or deterioration anywhere on the motherboard. In fact, everything on it still looks shiny and new.
Not sure what else to try troubleshooting. I've tried to boot the board completely bare in the past as well - no RAM, DRIVES, WIFI chip, CPU or GPU. Still same behavior with everything plugged in.
I'm out of ideas. Might have to just stick it back in the closet again.
Thanks for you help with the BIOS programmer, @runix18 !
If anyone comes up with any other ideas, let me know!
Hi, just wanted to ask a couple last questions about this motherboard beofe giving up on it:
What is the absolute bare minimum components I need plugged in to the motherboard to get a POST screen?
1. Will the motherboard POST without a CPU or GPU plugged in? (ie if it turns out my CPU or GPU are the culprit, would removing them allow me to at least get to the POST screen by itself? - in other words, would a bad CPU or GPU prevent a POST, while having no CPU or GPU allow a POST?)
2. Will the motherboard show any display without a GPU plugged in? I tried using an external display via the HDMI with and without the LCD cable to the laptop screen plugged in, but there was no external display either way, with or without the GPU card itself plugged in.
3. Can I try to flash the EC bios? Does this board have an EC bios? I flashed the regular BIOS chip with a programmer, but nothing changed. Someone in another forum mentioned the laptop behavior of no screen/no post/fans blasting/system shutdown might be a sign of the chipset's EC Bios not working properly. It may be waiting for a temp sensor reading from the CPU or GPU, and if it doesn't pick one up or isn't reading properly, it would trigger that emergency shutdown sequence before POST.
But I'm not familiar with EC bios or where that chip even is on this board. Nor do i think I even have that type of BIOS file for this board. Would flashing something like that help?
I'm looking for some way just to get to a bare-minimum POST screen just so I can work my way up piece by piece to figure out why it won't boot.
Thanks.
at minumum to POST you will need CPU, GPU and one stick of ram.
POST stands for power on self test.
the EC bios can be flashed I believe it's stored on an 8pin flash like the main bios on these machines, sourcing a file is a different story I'm not sure with that 😬 maybe someone else here with a p870 can provide one.
My Clevo P775dm3
8700k @4.7
3080mxm (180w)
32gb cl18
ok, thanks. before I try flashing anymore bios chips I'll get a cheap stick of RAM and see if that works with the replacement CPU and GPU.
I wouldn't even know where to find a EC bios for this board anyway lol. Finding a standard BIOS is a enough of a pain.
What are the chances both sticks of RAM went bad at the same time, and everything else works fine on the board? That's the only thing left I haven't tried - a new stick a ram. I tried swapping the current 2 ram sticks and using one then the other, in different sockets, but no POST with either of them. I figured the chances of them both going at the same time would be near improbable.
Thankfully there's a cheap stick of 2133 DDR4 8GB SODIMM for sale. 🙂
Hi Scourge,
No POST means there is a hardware issue.
If you have already replaced all the components without success, it is probably a problem with the motherboard. It might be a missing voltage rail for the CPU, GPU or RAM caused by a faulty cap or MOSFET.
If you have an EC problem, nothing will happen after you power it up, which is not the case. If you have a little knowledge of fault-finding, take the motherboard out and check for a short on each power rail. Take the resistance between ground (copper under the screws) and each coile. If any reading is near 0 ohm, that means the above.
On 4/12/2025 at 1:56 PM, Clyde said:
Hi Scourge,
Hi, I have a single stick of 2133 SODIMM 8GB of DDR4 RAM coming today that I'll try with the board, just to rule out the possibility of both the original RAM sticks being bad. Not really expecting it to help though. But it's the only thing I haven't tired yet.
I went digging through my old emails from 2018 and I do have a complete BIOS zip file from the resellers at the time for my Clevo (Prostar, which merged with Sager a couple years ago), and it looks looks like is has both the stock EC and Regular BIOS files in it. This is the original email they sent me with it:
Greetings,
Attached are the firmware files to update your BIOS. Since your EC firmware is already up to date, you can start at “step2” and then run “step3” after the reboot. What you’ll need to do:
1. Make a bootable USB thumb drive for FreeDOS
2. Unzip/extract the attachment and copy the files to USB drive’s root directory (don’t make any additional files or folders)
3. With the USB drive in the laptop, enter the computer’s BIOS setup, go to the Boot section, and disable UEFI
4. Save the BIOS change and boot to your USB flash drive
If you want to run step 1, that’s fine. It will overwrite the existing data for the EC firmware, then you can move on to step 2 and step 3 (all you have to do is type in “step1”, “step2”, or “step3” to run the corresponding update).
Kind regards,
Jeff - Prostar
According to the BIOS screen, I'm running: (as of March 9, 2018)
ME FW Version: 11.0.0.1197
MB Series P870DM-G
BIOS Version: 1.05.06RNS1
KBC/EC Firmware Revision: 1.05.03
VGA Card: NV GeForce GTX 980
VBIOS: 84.04.88.00.2E
And this is a screenshot of unzipped contents of the zip files:
But, as you said, if there's a defect on the motherboard itself, flashing the EC probably won't help anyway.
I'll see if a new stick of RAM fixes anything.
Thanks
Greetings,
Kind regards,
Jeff - Prostar
MB Series P870DM-G
Thanks
From P150HM to P570WM, I never had a single issue with EC/BIOS or the motherboard (I always used Prema BIOSs). And trust me, I did everything with Clevo laptops to break them down. But, after P570WM (and Windows 7),  many things, I guess, changed.
The P870xx looks like the last solid piece of equipment from Clevo, so I hope it's just a corrupted EC or an obvious hardware fault that you can easily fix. Anyway, by trying to fix it, you'll learn many things. 🙂
"Anyway, by trying to fix it, you'll learn many things. 🙂"
very well said 🙂 this is the best way to learn
My Clevo P775dm3
8700k @4.7
3080mxm (180w)
32gb cl18
11 hours ago, Scourge said:
Well, sad to report the new stick of RAM had no effect.
Eh, I think I'm done. Thanks for all your help everyone!
Don't give up like this.
1. Strip it down and connect to the mainboard (with cooling) the CPU, GPU, one RAM stick and external screen plus power button.
Power it up and see if it's POSTing.
2. If yes, power it down and connect the rest of the components one by one to see which one causes a problem.
3. If not, take everything off (CPU, GPU and RAM and check the mainboard for obvious damage (burns, all connector/socket pins), then measure resistance between the motherboard ground and all coils (except 19.5V and 3.3V rails, which are working).
4. If everything looks ok (no shorts), go to 1, power the board up, and check for the voltage presence on each coil (5V, 3.3V, 1.5V, 1V...).
You may need to power the board down and up a few times at each measurement.
If any coil has no voltage at all, you may have a more complicated issue like a faulty mosfet driver or missing driving signal (faulty resistor).
You are lucky it's Clevo, so you'll be able to find everything you need in the schematics in the Service Manual. But you'll need advanced knowledge about fault-finding.
Just give it a try.
Edit: Check for a faulty fan. That might be a no POST problem too.
Just give it a try.
Hi,
Thanks for your confidence, but I just don't have advanced knowledge on how to check individual resistors or caps or rails or any electrical stuff. I don't have a multimeter or any idea of how to use one to measure anything on the motherboard. I don't know how to solder either, so I wouldn't know how to replace anything soldered on the board anyway.
1. I stripped the board several times and booted to external monitor over HDMI, both with and without the internal LCD cable attached to the laptop screen. -having only the CPU/GPU/New RAM stick installed. Didn't POST in any configuration I tried.
2. All 3 fans spin for a minute on full blast before it shuts down. Every single time I try to boot it up.
Best I can hope for is to look online for a replacement motherboard, but I don't see many and I don't know if those boards are functioning or not either. Plus they are all pretty expensive for an almost 10 year old laptop.
  • 11 months later...
Not that I condone reviving threads, just saw you mention the result in another thread and thought it should be shared here for any passerby.
@Scourge ended up replacing the motherboard and also confirmed that all the original parts save for the motherboard all functioned as expected.
Something on the board had failed, though quite irritating (something I tend to experience with my experiments in the past) I am happy to hear that you were able to get it running again after replacing the motherboard.
Telegram / TS3 / Twitter
Yes! It was the motherboard. What exactly on the motherboard was bad, I'll probably never know. But everything I had on the bad motherboard works on the replacement board. And my new board came with the Premamod Unlocked BIOS on it, so for me this was an instant upgrade. Running Linux CatchyOS on it now instead of Windows.
